Are you sure? Could you explain to me how the RZ shock/linkage works on the RZ? If you are correct how much longer of a shock could I use if I am installing a 17" x 4.5" rear wheel with a 60 series tire? I think I'm going to need a new spring unless my rz spring will fit on an r1 shock. Thanks Jim
<br>
<br><hr size=3 width=75%><p>
jim.constantino@waterandsewer.org
