Well....as I discovered the RZV frame I have doesn't have the lower engine mounts. I've found them and their on the way....<p>Next I discover that the relay arm is not a direct pull off and bolt on. The allen head bolt that runs through the center of the swingarm where it bolts to the frame is about one centimeter short. I can source that locally and just on the way out to do just that.<p>Are their any other little bits that are going to crop up on me? Since several of you have done this before have you logged these little incongruities? If you've built yourself a list....please share. I'm attempting to move everything over as painlessly as possible. If no one else has a list made up I will compile one. If the only snags are the ones I've already encountered there really is no reason to make one, but considering the two things I started to work on became quickly obvious there was significant differences.....I'd bet there are more.........<p>Dale<br>
<br>
<br><hr size=3 width=75%><p>
wlasitz@shaw.ca
