my power valve cycles when the key is turned on and the indicator goes to the 12:00 position when i start the bike. when i rev the motor past 6000rpm the indicator moves downward slightly. i swapped the controller with a friend's (he says it works fine) and the power valve cycles like it should. when i start the bike the indicator goes to the open position (2:00) and stays there. the indicator doesn't move from the 2:00 position when i rev the motor with the borrowed controller. <p><br>any ideas?<p>thanks<br>robert
<br>
<br><hr size=3 width=75%><p>
parkside415@earthlink.net
