I wish to replace my shock with one from a F4 Honda. Does it matter the orientation of the shock - it appears that the reservoir could be located next to the battery, but this appears to be backwards relative to operational direction of the shock.<p>Thanks in advance
<br>
<br><hr size=3 width=75%><p>
gobrien@photocircuits.com
F4 replacement shock
Re: F4 replacement shock
All I can tell you is not to do it - it will cost as much or more as doing it right and buying an Penske or Ohlins or something!
<br>
roadkillrobert@yahoo.com
<br>
The spring rates are all different. You can do it, but why would you? Someone did it with an R1 shock I believe... check archives..<p>D<br>
<br>
wlasitz@shaw.ca
<br>
wlasitz@shaw.ca
I briefly considered it and was glad someone talked me out of it - the F3 shock is the best fit I think - I have the one that was closest here if you really want to try, you can have it. You will need to revalve, put a new spring on it and you have to drill your front mounts to match which will forever modify an irreplacable part - in the end you will spend as much as the aftermarket costs.<p>Rob
<br>
<br>
