Hi guys, <br>I would like to put new aluminum sheeting inside the plastic side cover. All i have found is a roll of aluminum tape about two inch wide for air duck use. I am looking for a sheet or maybe a roll the size of the one we use for cooking in the kitchen, witch is about 12 inch wide, but it needs to be a couple of gage thicker. <br>I can allways put the glu on myself, if it is not self adesif.<p>Any sugestion on were to look, would be appreciated.<br>Maybe firefighters stuff ??????<p>thanks<br>jp
<br>
<br><hr size=3 width=75%><p>
jean-patrick.lague@tva.ca
aluminum sheet, for inside panel
Re: aluminum sheet, for inside panel
I know they have that stuff for motocross plastic. Self sticking too. <p>I would think that would work.
<br>
Elvishead666@aol.com
<br>
You can get nice size sheets of self sticking from Summit Racing. It's peel and stick and you can cut it to size.
<br>
gpkotbh@aol.com
<br>
gpkotbh@aol.com
Don't know where you are but if in Canada, I found some peel and stick heat shield stuff at Canadian Tire that matches the stock stuff really close. It is in the part of the store with ventilation stuff. The matting is a rubbery stuff with the foil tape bonded to it - not the fiberglass matt like stuff in the originnal. It looks almosat the same when mounted and it was cheap, like less than $10 CDN for a huge roll about 8 inches wide.<p>Scott
<br>
ssmacdon@hotmail.com
<br>
Try contacting Cool tech or Thermo tech in the states as I purchaesd some self adhesive panels that are about 3mm thick and heat resistant which I applied to the rear cols as well as the battery box, looks standard, cheers mate.<p>Email: extrememotoimports@hotmail.com
<br>
<br>
