I want to swap a RZ350 (85 US) PV Controller to my RZ500 (85 CAN).<br>I have heard some wires need to be switched. Anyone know the tricks?
<br>
<br><hr size=3 width=75%><p>
mchadwick@charter.net
RZ350 to 500 PV Controller swap
Re: RZ350 to 500 PV Controller swap
not for sure exactly chadwick but It's in that rz500 tuning manual thats on ebay most of the time...
<br>
creswell5@cableone.net
<br>
No problems in doing that. Only the plug needs to be changed. The wires are the same colours, so the swap is rellay easy.<p>I have done it myself.<p>Steen
<br>
steen.lokke@tiscali.dk
<br>
I wired it the same but I can't get the rotation to open all the way. With the adjusters in the cable maxed out in one direction the valve will not open fully.
<br>
<br>
I think my cables are switched. I'll fix tonight and test.
<br>
<br>
In case you don't know this - they are actually numbered - there are numbers on the pulley between the cylinders and on the YPVS module - you just have to trace the cable (easier said than done i know) but just a tip in case you are not aware of this.<p>Rob
<br>
roadkillrobert@yahoo.com
<br>
I had the #1 to the #1 but I noticed that the cables are slightly different lengths. The difference should be just enough.
<br>
<br>
