It is currently Mon Jan 22, 2018 8:38 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
 Post subject: Re: Running stock upper pipes without heat shields
PostPosted: Mon Nov 07, 2005 9:52 pm
Hello everyone, I am running TSI spec pipes which don't have any heat sheidling, as the pipes were designed for this configuration. I have not wrapped them, nor have I ceramic coated them as this would increase the internal temperature and effect the way the pipe works. I took a different approach and used adhesive heat sheilding stuck to the inside of the faring and the underside of the tank. this made an amazing difference. The TSI pipes are a lot fatter in the belly and as such require a completely new customized rear fairing from the tank backwards. My bike is now a single seater with an emphasis on a GP style; bugger that the bottom TSI pipes cannot be routed to the right to look more GP whilst still retaining the original swingarm.<br>cheers <br>Pete
<br>
<br><hr size=3 width=75%><p>
pj_buchanan@yahoo.com.au
