Dry clutch kit and first gear set
Vendors can post special deals in here - Please, VENDORS ONLY
geosot
#1 Post by geosot » Fri Aug 20, 2010 5:31 am
I can offer a dry clutch modification for the RD500 on an part exchange base for a clutch cover.
Also I offer a first gear set with this modification.
OEM first gear ratio is 2.4 and OEM second gear is 1.68. With this kit first gear is 2.18 closing the gap between the 1st and 2nd gear.
Kit consist of
1. clutch cover
2. billet hub
3. first gear set (input shaft and output 1st gear)
4. primary gear with the small kickstarter gear pressed in.
5. Seals, o-rings, nut, additional external oil feed.
6. short pushrod for the Ducati pressure plate
Kit uses Ducati basket, pressure plate and disks/springs. I can supply these parts or you can get them from another source.
Note that the kit requires the modification of an existing clutch cover, that you have to supply me.
Fitting of the kit requires the removal of the quasi cassette gearbox and access to a hydraulic press to disassembly & reassembly the input shaft.
Optionally
1. I offer a 1st - 2nd gear set with the kit with longer 1st & 2nd for race circuit use (at additional cost)
2. offer replacement for the NLA gearbox bearings (at additional cost)
3. offer a kit that uses Ducati hub and utilizes OEM first gear (that drastically reduce cost)
rzatch
#2 Post by rzatch » Fri Aug 20, 2010 10:42 am
cost???????????? I know there are variables from your post but a baseline cost would be nice.
geosot
#3 Post by geosot » Fri Aug 20, 2010 2:36 pm
rzatch wrote:cost???????????? I know there are variables from your post but a baseline cost would be nice.
The modification is quite modular and a price tag at this point could be misleading.
I have send you a PM with a detailed price analysis.
rzatch
#4 Post by rzatch » Fri Aug 20, 2010 5:50 pm
Got it, thanks :grin:
Blackshaheen
#5 Post by Blackshaheen » Tue Aug 31, 2010 9:45 am
I'd like that list as well please!
Cheers.
84rzv
#6 Post by 84rzv » Wed Sep 01, 2010 7:30 am
could i please have the price list as well?
Will this work with a slipper clutch also
Cheers Phill
0094
CCCoooooooooollllllllll!!!!!!!!!!
#7 Post by 0094 » Wed Sep 01, 2010 11:54 pm
Hi, that looks fantastic. Can I have a price too, thanks.
James Hunter CLUBRZ Australia / Extreme Moto Imports
geosot
#8 Post by geosot » Mon Sep 20, 2010 4:08 am
Here is a test fit before a kit goes to the owner. This is a dry clutch kit with billet hub plus a first gear set.
geosot
#9 Post by geosot » Mon Sep 20, 2010 11:08 am
Also the kit based on TZ350/TZ250 parts is again for sale.
This kit is superior to the Ducati based kit, but it costs.
TZ parts are really pricey and even the maintenance (disks, springs) cost.
On the other hand life expectancy of this kit with moderate (ab)use is way to long.
geosot
#10 Post by geosot » Thu Sep 30, 2010 9:19 am
Some pictures of
1st and 1st/2nd gear sets for dry clutch.
a complete 1st/2nd gear kit with hydraulic clutch mod and VJ22 rotor/stator (requires a DC-CDI and wiring modification) and a 1st gear set:
Many thanks to the member here that let me publish pics of his parts, while they are waiting the clutch cover to be shipped to their owner all together.
TZRZVRD
#11 Post by TZRZVRD » Fri Oct 01, 2010 7:02 pm
84rzv wrote:could i please have the price list as well?
Cheers Phill
just wondering, why would you need a slipper clutch on a 2 stroke?
Use "no way" as way
Have "no limitation" as limitaion
txk232
RZRD500
#12 Post by txk232 » Tue Nov 02, 2010 2:17 pm
TEST
txk232
#13 Post by txk232 » Tue Nov 02, 2010 2:20 pm
Hi can I get It to thanks MEGALE
geosot
#14 Post by geosot » Wed Nov 03, 2010 4:00 am
txk232 wrote:Hi can I get It to thanks MEGALE
Many thanks.
PM sent
ncr160
#15 Post by ncr160 » Wed Dec 01, 2010 2:01 am
Hi
I have started the same project but with adaptables parts. I will put pics and informations as soon as possible. regards
