new guy here too!! 1985 RZ500RN
pstamper
Re: new guy here too!! a triple, rz500 AND a BB chevelle!!
#331 Post by pstamper » Sun Jun 23, 2013 4:00 pm
You need bigger pans under it. Sounds good. You still having cool nites for break-in? I rode mine all nite on the first initial heat cycles so the engine would cool down all the way. Even had a state trooper stop when at a gas station at 3 AM to see if all was well. No motorcycle license, but we talked about the bike and he never asked to see it.
bolly
#332 Post by bolly » Fri Jun 28, 2013 12:09 pm
not too bad here pstamper but a couple days where highs were 91!!!! unseasonably hot for here :( too many days of rain lately though.... great day yesterday so a full tank of just about 100% straight gas and out for a 70km round trip, ran like a top!!!! (about 125km's since rebuild)
pstamper
#333 Post by pstamper » Fri Jun 28, 2013 2:08 pm
That is good to hear and makes you feel good. Rick always told me to run it thru heat cycles to get everything to seat in and stabilize. My break ins would be a 6 hour night ride with lots of stops. Always ran Suzuki CCI oil for break-in and then went to better oils after break-in. Everyone has there own way to break an engine in so who can say what the best method is. We are at 100 this weekend and no rain.. If not careful we will be like Colorado. We need rain.
bolly
#334 Post by bolly » Thu Jul 04, 2013 11:32 am
luckily I knew a guy who knew a guy who had some tygon as absolutely nothing is available locally so new 3/16" F-4040-A main oil line to pump installed (old one was cracking at the reservoir nipple), he didn't have any 1/8" so left injection lines stock...
400km's sofar!!!! :smt041
bolly
#335 Post by bolly » Sun Jul 28, 2013 6:29 pm
bike is runnin like a champ fellas, no leaks anywheres that I can tell.... about 917 big grinnin km's sofar!!!! :smt040
pstamper
#336 Post by pstamper » Sun Jul 28, 2013 10:05 pm
That is good to hear. Happy for you. US PLastics for oil lines if you decide to replace. Small engine shop or RC shop also.
solo 2
#337 Post by solo 2 » Mon Jul 29, 2013 9:22 am
Good to here it's running well, try Canadian tire for the fuel line, it's in the motorcycle section made by Ignition. I'm pretty sure it's tygon as it's very soft and stays that way, I use it on my bikes as fuel line so I can see it. Only comes in pink for the 1/8", if you don't mind that it's a cheap option.
bolly
#338 Post by bolly » Sun Aug 18, 2013 1:45 pm
regreased rear suspension recently, coolant level is steady and holding, same as trans oil... so it seems no leaks, plug colour seems to be running slightly rich but that's better than melted electrodes LOL!!!!
1200km's and counting... which is just about where she was when the right upper went last time... but I got a good feeling about how she's runnin this time!!!! (fingers x'd LOL!!!!)
Blackshaheen
#339 Post by Blackshaheen » Sun Aug 18, 2013 3:12 pm
:mrgreen: :mrgreen: :mrgreen: Stoked for you Bru!!!!!!! I pray I get the same success in a few months.
D.
bolly
#340 Post by bolly » Fri Sep 27, 2013 9:17 pm
thanx Blackshaheen!!!! unseasonably nice weather here so I ventured further that I ever ventured with her before... 400km roadtrip and made it back 15 minutes before it got dark.... maxed her out to 140km/h at 6100rpm in top gear (speedin tickets can cost $10,000 here :smt010 )
other than some singular bits of backfiring at part throttle it ran like a champ!!!!
solo 2
#341 Post by solo 2 » Sun Sep 29, 2013 10:37 am
That's great to hear Greg, I'm still hoping I can get mine broken in this year.
bolly
Re: new guy here too!! rz500rn
#342 Post by bolly » Sun Oct 13, 2013 11:10 am
ok men, running good so I head out for a rip yesterday and all's fine on the hiway, turn into town and then not so good at idle/part throttle, almost like the pilot air jet problem I originally had but I removed them and they're clean as a whistle... removed all plugs and a couple looked slightly fouled so replaced with new ones... problem is won't idle properly have to give it more twist to keep running and to start off.... I'll remove the carbs today and givem a good cleaning and try again.... damn I hate re and re them damned carbs LOL!!!! :(
2smoke
Re: new guy here too!! 1985 RZ500RN
#343 Post by 2smoke » Sun Oct 13, 2013 12:23 pm
Hi Bolly
Idle and ride away is all pilot jet as you already know.
Most problems are in the carbs on these bikes.
Which plugs are effected, and are they fouled with oil or wet with gas?
I am thinking dirt or rust stuck in the carb. Good luck, let us know how it goes.
bolly
#344 Post by bolly » Sun Oct 13, 2013 8:33 pm
colin yoiu nailed it... all sorts of crap and corruption came out of my carbs!!!! anyways all cleaned up now and revvin crisp and clean!!!! :grin:
but........ the lower left carb is pukin fuel out the overflow so off the left bank has to come again... damn them carbs!!!! :smt013 LOL!!!!
bolly
#345 Post by bolly » Sun Oct 13, 2013 9:04 pm
all 4 main jets were slightly constricted and all 4 pilot jets were 1/2 plugged solid with loose deposits, bowls had noticeable sediment and some some chunks..... lotsa crud collected in my parts washer after finishing all 4!!!! sadly I dont have air so all I'm workin with is a can of brake clean and a tupperware container!!!!
