More RZV mods.....
Donald Duck
More RZV mods.....
#1 Post by Donald Duck » Thu Nov 21, 2013 7:50 pm
If you do the R 6 conversion and you want your bike to turn, steering lock to function and the stock speedo to work, let me know. :smt004
Donny
kpke
Re: More RZV mods.....
#2 Post by kpke » Fri Nov 22, 2013 12:44 pm
Beautiful bike! I have seen it progress on one of the other sites.
Would like to know the R6 lock to lock trick please.
Thanks,
Ken
Donald Duck
#3 Post by Donald Duck » Fri Nov 22, 2013 7:34 pm
I cut off the stock R6 & RZ stops and installed the two aluminum blocks with some Marlite attached at the contact zone (fork tubes) I saw this at the Long Beach show in 2011 on a GSXR race bike. If you want some of this Marlite i have enough left over for 100 bikes, I'm giving it away for free. Tell me if you want the dimensions of the material. Look and you will see the stops in the pic.
Andrew
#4 Post by Andrew » Mon Nov 25, 2013 12:11 pm
Good idea :smt023
Andy (UK)
RZV500R
FRC
Faster Faster !!!
rd84
#5 Post by rd84 » Tue Nov 26, 2013 7:34 am
Nice Bike Donny ! - How did you get the stock speedo to work please ?
Donald Duck
#6 Post by Donald Duck » Tue Nov 26, 2013 2:08 pm
I'm glad someone finally asked. The drive unit is called Cable X, The company is located in Pine Bluff, Arkansas that makes it. The box is about 1 7/8" x 3 1/2" x 4" and weighs about 2 lbs. ,the drive cable is around 36" long. I'm using a Anti Gravity 12v lite weight battery and the draw is next to nothing, so no problem there. I chose to mount it under the tank, It fits nicely once you remove that stupid airbox. You can use a sensor on the front or rear wheel, I used a GPS receiver mounted under the tail section ( no exposed wires ). The good is it works great and you can't see it, The bad is it costs 350. 00 for the box, 145.00 for the GPS, 35.00 for the cable and 30.00 to have one end of the cable modified by a speedo shop and it weighs aprox.2 lbs ( I pinch loafs that big). I think this the only way possible to keep and use the beautiful stock instruments. This is the link that shows the cable X in action.
http://youtu.be/kZi9Sxwysk0" onclick="window.open(this.href);return false;
Donald Duck
#7 Post by Donald Duck » Tue Nov 26, 2013 2:16 pm
I forgot to mention that the box is fully adjustable by way of dip switches, My speedo of course reads in Kilometers, so for instance i'm doing 80 kph, It's really 80 mph or ever which way you want.
rd84
#8 Post by rd84 » Fri Nov 29, 2013 6:38 am
Hi Donny,
Many thanks for your explanation - sounds a good idea for keeping things looking original.
Ronnie
#9 Post by Ronnie » Sat Nov 30, 2013 5:26 am
That's brilliant, if a bit pricey. Well done. :-)
WVWRZ500N
#10 Post by WVWRZ500N » Sun Dec 01, 2013 2:16 am
Donald Duck wrote:If you do the R 6 conversion and you want your bike to turn, steering lock to function and the stock speedo to work, let me know. :smt004
Donny
Donald,
What is the extra red switch in the left hand handlebar switches?
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
nzminis
#11 Post by nzminis » Sun Dec 01, 2013 3:32 am
i did not notice that the us bikes did not have that switch
its a pass switch , just flashes the headlight they dont work very well and are pointless , i have never used them on any of the bikes i have owned
Donald Duck
#12 Post by Donald Duck » Sun Dec 01, 2013 11:02 pm
The jap model also has function switch on the other side that the fuel/temp gauge is operated by ( FYI ).
jredgrave
#13 Post by jredgrave » Wed Oct 01, 2014 9:57 pm
Hi Donny,
whose upper triple clamp is that? I assume that is how you get the steering lock to work.
Thanks,
jason
donnydotson
#14 Post by donnydotson » Mon Apr 13, 2015 12:25 am
Only made two or three and yes, that's how it works.
Donny
RG500
1098
Tote goat
#15 Post by Smoker » Tue Apr 14, 2015 4:56 am
Very nice work!! :smt007
I too have a few questions.
Where is your build thread located? (I'd like to see more of your work.)
What year R6 forks are you using?
Is that the OEM RZV ignition mounted in your upper triple?
Could you give the stem center to ignition lock center measurement?
What are the 2 allen head bolts on the upper triple for? (Locking the clip-ons?)
You gonna bring it to Hanson Dam next month? :smt006
