Track scooter upgrades for COTA weekend
Posted: Tue Oct 25, 2016 10:39 pm
by pstamper
Re: Track scooter upgrades for COTA weekend
Posted: Tue Oct 25, 2016 10:47 pm
by silverstrom
Your bike looks amazing. Hope you have a great weekend.
Posted: Wed Oct 26, 2016 9:57 am
by pstamper
I ran the street version of the Pirellis last time and incredible tire. I just need to maintain heat in the tires. The Brembo master cylinder should be one finger pull. I was stopping at 175 to 200 feet on back staright which is 3/4 of a mile long and he said 150 should be good now. He recommended the Versah pads. I am running the EBC GP pads. Was still not using all the front tire so we took a little preload out and might raise the back a little. If I still do not use all the tire we are going with stiffer springs and less preload so the front dives better and does not want to come up mid corner.
Posted: Wed Oct 26, 2016 2:08 pm
by Speed Freak
WWhat do you mean with "not using the whole front tire"?
If you mean that you don`t use it down to the edge - forget it with the RD500...
My old R1 is scratching with everything on the track before I use the whole front tire
Maybe with modern bikes, but even there the front tire is made for more lean angle than the bikes allow.
The tires I`m using since 2 years (Dunlop KR and Bridgestone V02) even don`t have an edge where you can judge if you use "the whole tire".
I`m interested in your experience with the Brembo master cylinder.
I have nearly the same configuration, you are only using the golden brake calipers (from R1 RN09+) with aluminum brake pistons instead of steel pistons in the blue calipers.
My plan was to have a brake where the rear wheel gets light at 250km/h with 2 fingers like my standard CBR1000 with EBC pads... but nearly no difference to the standard master cylinder (Lucas CRQ + standard brake rotors).
Hope the Brembo brake pads will improve the performance next year.
After one year of usage the master cylinder starts with a "cracking" noise in "18" position - seems to be a common problem.
No influence on function, it`s just a wear problem between the pin coming from the lever and the piston.
And if it starts leaking - there is no repair kit available from Brembo. This is the reason why I would never buy it again.
The only way to get it repaired is to send it to Brembo, I guess it will be nearly as expensive as buying a new one...
Posted: Wed Oct 26, 2016 2:44 pm
by pstamper
I also thought it was a geometry issue with bike. We are talking about 3/8 of an inch. I do hit the shift lever due to an extension I installed. My tire guy seems to think I am not loading the front enough. I had a lot of preload on the springs when I set it up. I am not using all the stroke in the forks. He was thinking an 85 LB spring with less preload. He did not measure but said it appeared to have a lot of trail. We took two turn out on preload and added a click of rebound. Will see this weekend.
As for brakes, I went to the Brembo due to faulty clutch master cylinder. I figured I would install both. He said the pull should be one finger. I am going to set it on the lower ratio to start with. He said the Versah pads are much better than the EBC ones. He also said there is an issue with the EBC rotors and the SD attachment system getting loose due to how much contact patch they have. The Brembo is suppose to be a better rotor but I am not spending that for track day use.
I am the weak link with the bike. I just hope the clutch gives me no issues and the new master takes a short time to get used too. The back staright at COTA is 3/4 of a mile long. Those 1000RRs are like a missile coming at me. They pass me about 2/3 of the way down the straight but if no one is in the way I can usually move inside and pass them under brakes before the left. All I want is a little more confidence to go 50 feet further before braking and I should be much better.
I really want to ride one of the RRs. Nate Kern does two up rides at most events but I am scared I will pee my pants.
Thanks for the input from another track guy.
Posted: Wed Oct 26, 2016 4:03 pm
by podman
Im excited for you, look forward to seeing the pics and video of course, have a great time.
Posted: Wed Oct 26, 2016 8:58 pm
by two-stroke-brit
Thats what "depends" are for
Posted: Thu Oct 27, 2016 6:25 pm
by pstamper
I just bought baby wipes due to the heat off the seat. No red arse for me this weekend.
Posted: Thu Nov 03, 2016 8:21 pm
by two-stroke-brit
how is the hydraulic clutch working ?
mark
Posted: Thu Nov 03, 2016 8:50 pm
by pstamper
New clutch master worked great. He said bleeder was cracked. Operation of the clutch is way smoother. Brakes better also. You see the pictures just posted?
Posted: Thu Nov 10, 2016 2:49 pm
by two-stroke-brit
pstamper wrote:New clutch master worked great. He said bleeder was cracked. Operation of the clutch is way smoother. Brakes better also. You see the pictures just posted?
yes i did.
