Front stay
RZ-RD-RZV.... and everything in between
cainpole
Front stay
#1 Post by cainpole » Sat Aug 24, 2019 4:30 pm
Are there differences between front bird cage on the rzv and rz 500 and if so will the rzv cage fit the rz500?
tacky1
Re: Front stay
#2 Post by tacky1 » Sat Aug 24, 2019 6:42 pm
Yep. Both are the same.
cainpole
Re: Front stay
#3 Post by cainpole » Sat Aug 24, 2019 7:24 pm
Thanks Tacky1!!
Re: Front stay
#4 Post by silverstrom » Sat Aug 24, 2019 8:00 pm
The RZV part # is 1GG-28356-00 and uses an 8 mm mirror bolt
1GE is 1GE 28356-00 and uses an 8 mm mirror bolt.
47X is 47X-28356-00 and uses a 10 mm mirror bolt.
That is what the fiche says, but I bought an RZV stay direct from Japan and it came with 10 mm nuts for the mirror bolts. I have one of each here, but now I'm just confused.
tacky1
Re: Front stay
#5 Post by tacky1 » Sat Aug 24, 2019 10:35 pm
Hmm, I didn't have a problem with mine John, One is an RZV and one is an RZ and I sold a few and they all had 8mm bolts....
cainpole
Re: Front stay
#6 Post by cainpole » Sun Aug 25, 2019 12:19 am
Not concerned about the size of mirror bolts because my stay has no ears for mirror attachment PO cut them off and put rubber plugs in the holes.
Re: Front stay
#7 Post by silverstrom » Sun Aug 25, 2019 12:46 am
tacky1 wrote: Sat Aug 24, 2019 10:35 pm Hmm, I didn't have a problem with mine John, One is an RZV and one is an RZ and I sold a few and they all had 8mm bolts....
Jackson.40 discussed it a while back. The parts lists show the differences. Not sure why there is a difference.
viewtopic.php?f=14&t=7312&start=60
bokusouchi
Re: Front stay
#8 Post by bokusouchi » Mon Aug 26, 2019 5:58 pm
there are 4 different front stays :
steel frame :
47X-28356-00 ( for 47x , 10 mm bolt holes for mirrors , the boxy part that bolts on the main frame (steering stem) is narrower (10 to 5 mm ) (due to steel frame i guess)
1GE-28356-00 ( for 1GE , 8 mm bolt holes for mirrors , the boxy part that bolts on the main frame (steering stem) is narrower (10 to 5 mm )
aluminium frame :
51X-28356-00 ( for51X , 10 mm bolt holes for mirrors , the boxy part that bolts on the main frame (steering stem) is wider ) (due to aluminium frame i guess)
1GG-8356-00 ( for1GG , 8 mm bolt holes for mirrors , the boxy part that bolts on the main frame (steering stem) is wider ) (due to aluminium frame i guess)
bird cages for aluminium frames (51X-28356-00 and 1GG-8356-00) can be used on steel frame if one adds some spacers/collars (opposite is not true )
basically 1GG is for the 51X what the 1GE is for the 47X (a kind of second generation with small and not so so small modifications )
ChequeredFlagRacing
Re: Front stay
#9 Post by ChequeredFlagRacing » Thu Apr 09, 2020 9:40 am
RZV stay
RD Stay
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Yamaha AS3 125cc 1978
Yamaha AS1 125cc 1979
Honda CX500
Honda MT125cc 1980
Yamaha TZ125G 1981-82
Zeger TC500cc 1983-84
Yamaha RD500LC 1985-87
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
rzatch
Re: Front stay
#10 Post by rzatch » Thu Apr 09, 2020 2:45 pm
Top picture with the addition of spacers will fit both bikes. Bottom picture will not unless you cut the spacers off.
cainpole
Re: Front stay
#11 Post by cainpole » Thu Apr 09, 2020 4:40 pm
Thanks for the photos. Does anyone have either one that they are willing to part with? Don’t like riding without mirrors. Previous owner cut off ears that mirrors are attached to.
rzatch
Re: Front stay
#12 Post by rzatch » Fri Apr 10, 2020 12:26 am
Speed Freak
Re: Front stay
#13 Post by Speed Freak » Sat Apr 11, 2020 4:19 pm
I have a few questions to the front stay.
Can somebody with a good (NOS?) one answer them?
Mine seems to be a bit twisted.
