fuel cap place ment/
peet2-her
#1 Post by peet2-her » Tue Mar 17, 2009 11:34 pm
just been watching rz video tech on u tube. the rzv they use has a filler cap placed on right hand side of centure . also the ally frame has 2 bolt lug on inside of up railes . would this bike be a prototype machine ?. cheers peet.
rztom
Site Admin
#2 Post by rztom » Tue Mar 17, 2009 11:50 pm
None of the RZ/RD series had the fuel cap anywhere but dead center on the tank... so suspect it may have been a custom?
Got a link to the u-tube video?
peet2-her
#3 Post by peet2-her » Wed Mar 18, 2009 12:15 am
http://www.500v4.com/yamaha_500_rdlc_50 ... nique.html first one dont work try this . got it open on anoyher window having trouble coping it over.hope this one works this edit button works well . it in rd tech over view. at bottom. peet
#4 Post by Smoker » Wed Mar 18, 2009 12:52 am
Yep, I saw it.
The fuel filler cap on the OEM RZ500 in the video is in the same position as on the '84-'85 RZ350 USA version.
Very interesting!
peet2-her
#5 Post by peet2-her » Wed Mar 18, 2009 1:17 am
how diffrent is the rz350 tank to the 500 tank . did you see thr black seat cowel knobs to. prob lots of dif in there . peet
Jeff B
#6 Post by Jeff B » Wed Mar 18, 2009 9:31 pm
I believe the tanks are quite a bit different.
Did you catch the choke lever? It looks a lot different than mine.
rztom
Site Admin
#7 Post by rztom » Fri Mar 20, 2009 10:59 am
That video is the original service video from Yamaha. The RD in the vid was a prototype with several prototype parts fitted, hence things like the unusual-looking choke.... :-)
