500 Two-Stroke Tech
500cc GP-Replica Tech Forums
Search  FAQ  Register Login
It is currently Tue Nov 13, 2018 5:30 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject:
PostPosted: Fri May 15, 2009 3:40 pm
hi is this what you re looking for ?
Ebay link
shift cam assy is also on ebay.de
 Post subject:
PostPosted: Fri May 15, 2009 10:33 pm
no but for 1.00 sure
 Post subject:
PostPosted: Mon May 18, 2009 12:03 am
no bearings yet, I found all my shift forks, shafts and drum, anyone :sad:
 Post subject:
PostPosted: Mon May 18, 2009 12:11 pm
Gus..... maybe it s an idea to post some sizes from those bearings :???:
ID-OD etc..
we can al search for an alternative one
 Post subject:
PostPosted: Mon May 18, 2009 3:44 pm
Here is more info on the bearings and size.
http://www.rzrd500.com/500phpBB3/viewto ... ht=bearing
 Post subject:
PostPosted: Mon May 18, 2009 7:42 pm
I found that when I wanted bearings made for my crankshafts, KOYO would not do them as they were OEM only. I can get all 4 bearings made, but they want to make 1000 of each one. And the whole bill will probably be under $6500 USD, which is cheap. The problem is.......What the heck am I going to do with an extra 954 bearings, because thats about the number Ill have left. IF they'll let me purchase 100 of each I would do that. But hang in there I still have not heard back from Eddie.
 Post subject:
PostPosted: Tue May 19, 2009 8:06 am
Gus, You've probably been through this nine ways to Sunday, but in case you haven't come across them;
http://www.precisionbearings.net/
http://www.bearingworks.com/index.php
I think RGVSteve put me onto these guys.
 Post subject:
PostPosted: Tue May 19, 2009 12:44 pm
the tall clutch bearing is the most difficult one , 25-47-8.5 is an unusual size
in every engine i opened they ve installed ball bearings , only yamaha goes for needle bearings :shock: :sad:
we need to change to a ball bearing with double races if we want to find a matching one
 Post subject:
PostPosted: Mon May 25, 2009 9:05 pm
lets move on without the bearings until Ed gets back with me or someone else, I have a set of ported barrels something like TSI I think and would like to change the head a bit some thoughts?
 Post subject:
PostPosted: Mon May 25, 2009 9:59 pm
What pistons are we going to use? I mean, then head needs to match (squish band and all). I have a TZR 3MA head that has a much nicer chamber than the RZ500's if you want to look at that. I think it's doable on the 500 head without having to hit the "add metal" or "remove metal" buttons too much.
Fuel Injected RZ350
 Post subject:
PostPosted: Mon May 25, 2009 10:20 pm
Steve is that the 1KT head?
 Post subject:
PostPosted: Mon May 25, 2009 10:34 pm
No, it's a 3MA reverse cylinder head. Much nicer looking than a 1KT/2KT head (which is nearly the same as the 500 head). Wider squish band, better bowl, (less of a cone than the 500's) etc... We are talking 5 years later in the 2T development. Probably the best street going (pump fuel) 2T chamber that there will ever be.
Not that it would bolt on, as the 500 head has a bigger cylinder spacing, but we could copy the chamber.
Fuel Injected RZ350
 Post subject:
PostPosted: Tue May 26, 2009 3:48 pm
Gus , the 2MA-1kt /2XT head fit straight on .....3MA does nt ....see pic
left is 1KT-2MA and 2XT also (about same as RD500)....right is 3MA (wider squishband)....uses the longer treaded plugs also
 Post subject:
PostPosted: Wed May 27, 2009 9:16 am
our good friend Mark Brown (GP Customs) has given me a few heads and cylinders off a 1KT to play with, PV's were different than the 500 and no fill for water in the cylinder I think this is where the cooling mod on the engine topic originated from because they must be routing the water out of the cases as it goes in the head but no outlet, I have never seen one so am not sure, but my thought on the heads is removable domes so we can do what ever we want, I will post a pic of Gary's heads and we can go from there.
 Post subject:
PostPosted: Sat Jun 13, 2009 9:06 pm
guys been doin a bunch of dumb stuff, (dont ask) and now is the time to get the motor together, Eddie will be at my shop friday, and this guy works magic on the overseas side of things, I am gonna give him a bunch of things to get started, so until then I'm going with those ported barrels and the custom domes, cool?
