new RG500 owner wheel advice
Hi guys just bought a Rg500 to go with my tzr and rd500, after doing a little research am I right in thinking GSX600 wheels are a direct bolt on for this? apart from taking 11mm off cushdrive? and the front direct bolt on no mods at all?
Suzuki Rg500
Yamaha RD500 Hybrid
Yamaha R1 1998
Yamaha TZR250 3xv
Yamaha super tenere 1991
Suzuki RGV250 VJ22 1996
Suzuki RGV250 1992 tyga VJ22
Yamaha R1 4XV 1999 Harris
Suzuki T500 1973
Yamaha RD500 Hybrid
Yamaha R1 1998
Yamaha TZR250 3xv
Suzuki T500 1973
Re: new RG500 owner wheel advice
3" front up to 98 gsx600f wheel fits with no mod's, I have one with new bearings and paint If you live in uk.
Rear needs machining and a bearing change to fit.
Get your self over to the RGV forum, as this is a well dicussed common mod.
http://www.rgv250.co.uk/forums/index.ph ... rg-series/" onclick="window.open(this.href);return false;
thanks for info, how much you want for it, it comke with disks? any idea on what machining is needed?begbie wrote:3" front up to 98 gsx600f wheel fits with no mod's, I have one with new bearings and paint If you live in uk.
Suzuki Rg500
Yamaha RD500 Hybrid
Yamaha R1 1998
Yamaha TZR250 3xv
Suzuki T500 1973
Yamaha RD500 Hybrid
Yamaha R1 1998
Yamaha TZR250 3xv
Suzuki T500 1973
As stock the wheels on an RG can be anything upto 10mm out of line !
Before you start make sure your frame, forks and arm are straight. Dont think because someone else had to machine 13mm from the spr carrier you should do the same.
I dont know how much help I can be but the RG I just bought has a GSXR conversion
- rg9 copy (Medium).jpg (204.71 KiB) Viewed 3468 times
