My RGYZ 500 project... but will be RSYZ 500 !
Sub forum for RG400/RG500 owners and enthusiasts
solex27
#1 Post by solex27 » Sun Feb 14, 2016 7:11 am
Hi,
See the state of my project RG500 engine with YZ 125 1C3 top ends.
I did the cad study:
moteur RGYZ500 3D (2).jpg (199.4 KiB) Viewed 4268 times
moteur RGYZ500 3D.jpg (171.58 KiB) Viewed 4268 times
... then the engine after (many) work :
rd84
Re: My RGYZ 500 project... but will be RSYZ 500 !
#2 Post by rd84 » Sun Feb 14, 2016 7:19 am
That looks amazing!
Vin
#3 Post by Vin » Sun Feb 14, 2016 7:23 am
Stunning work :cool:
solex27
#4 Post by solex27 » Sun Feb 14, 2016 7:27 am
other picts:
Setup engine:
- RG 400 cases
- 4 YZ 125 1C3 top ends rebored to 56mm et fully reworked + new nickasil
- 4 KTM 144 Woesner pistons
- 4 RM 125 rods 110mm fitted on news RG500 webs
- 2 specials plates to fit YZ cylinders
- water pump reworked to have an external out (better flow with water inlet on the front of the cylinders)
- stock carbs rebored to 31-32 diameter (oblong), the max we can do.
- Piaggio 125 DC rotor/stator (600g less). Same cone and pin than RG.
- new cheap racing gearbox design by me, built in italy, sold by FPE Engineering.
- special primary shaft for Z750 kawa clutch.
- and many small things....
For the moment I'm fitting the engine in my RGV frame to start the exhausts work but engine is planed to be used in a RS 250 aprilia frame with R6 08-15 swingarm (I will keep the RGV frame for my 2nd engine with RGV barrels, project stopped for the moment but 80% work done)
I will also used a self supported rear seat with the RS frame, special made by Thomas Michel from Carbon & composites applications:
https://www.facebook.com/media/set/?set ... 843&type=3
It will be the same than on facebook pictures but for me it will be closed on the seat to use a seat foam (more place for upper pipes)
#5 Post by Smoker » Sun Feb 14, 2016 1:55 pm
Vous êtes un maniaque.
Et je l'ADORE! :smt007
podman
#6 Post by podman » Sun Feb 14, 2016 2:10 pm
That looks fantastic, look forward to the updates on its progress.
geakins
#7 Post by geakins » Mon Aug 29, 2016 3:02 am
Nice!
What kick starter are you using?
