Modded RG500 in England
Sub forum for RG400/RG500 owners and enthusiasts
ns86
#1 Post by ns86 » Fri Aug 18, 2017 10:57 pm
17,500 GBP $28,500 CDN http://www.ebay.ca/itm/Suzuki-rg500/172 ... 0005.m1851" onclick="window.open(this.href);return false;
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1985 NS500 Spencer p
1989 TZR500 Biaggi p
1984 RZV500 Rainey p
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
Rick Lance
Re: Modded RG500 in England
#2 Post by Rick Lance » Sat Aug 19, 2017 1:34 pm
Wow. Where to begin....
Let's work front to back. You have high dollar Ohlins forks with nice clamps and Brembo calipers with China cheap-o rotors. The brake reservoir blocks the view (from the saddle) of the temp gauge. There are no fork stops on the lower T-clamp because the bars never turn far enough to make use of them. The USD's interfere with the fairing bracket midway through the stock turning radius. All in all, a nasty combination of parts that will get you hurt. I can't tell for sure, but it looks like a 3x17 RGV front wheel with a 120 tire which creates an unstable profile and should be fitted with a 110/70. The tire is brand new so I can't see a wear pattern but it is a common mistake. The RGV swingarm and rear wheel assembly with hugger fender is totally incompatible with the stock exhaust and will impact the pipes mid travel with evil effect. No comment on the shock. The RGV sprocket cush drive is very weak (hollow engagement fingers) and expecting half the torque of the 500 output and has been known to fail. The speedo shows less than 4k miles. I highly doubt that's accurate. Says the motor is original with no piston rattle. I've never known a water cooled motor to have audible rattle before a piston failure. Missing mirrors aren't easily replaced. There's no functional key operated steering lock since the forks can't turn far enough to reach the edge of the lock tab on the frame.
ns86
#3 Post by ns86 » Sat Aug 19, 2017 4:50 pm
Great review Rick. You have provided a great service for prospective buyers
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
MK
#4 Post by MK » Sun Aug 20, 2017 6:27 am
I can confirm the failed rear cush drive using it on my RD500.
Not a nice situation when you're overtaking a big truck and suddenly your engine just revs like hell, but there's no more acceleration. I was lucky the chain didn't block the rear wheel - that'd at least doubled the fun ...
ns86
#5 Post by ns86 » Tue Aug 22, 2017 6:08 pm
Listing ended by seller Aug. 20 NLA
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
