Hello
I have recently bought an RG500. Does anybody know if the red oil light should come on when the ignition is turned on and then go off once started, or does it only come on when the oil level is low? The owners manual doesn't really explain very well.
Thanks jeremy
RG500 oil light
Re: RG500 oil light
Just checked mine there Jeremy, it gives a brief flicker as you turn on ignition then stays off.
Please keep diesels from our roads
