RG500 Streetfighter Project
Re: RG500 Streetfighter Project
Not a big fan of the streetfighter style but this build looks pretty amazing. Will really be interesting to see it finished. Nice work so far.
- Mike Cichetti
Looks really nice!
- Ronnie
Nice one Nick! You've certanly cornered the market for those Honda Hawk swing arms.
This one is a 1996 VFR750 single sider.
Must see more!!!
Really nice machine work on those triples.
Its all coming together bit by bit.
How's the street fighter project coming along?
yes indeed how is it coming along , what I want to know is how are the cruzin image RG 500 pistons working ( If engine is finished being put together ) kind regards Andrew p.s. last saw you in Pomona with your dad , and your RZ350 long time ago at bike night ............
Its coming along slower than I like, sort of lost some motivation working at Simi Valley Cycles for the last 3 1/2 years.
A lot of negativity and the way the store is run by the manager. Read the Yelp reviews, it speaks for itself.
I did score a nice used WW key set, which includes the gas cap, seat lock and ignition with the Genuine WW key and a bike lift from http://www.rg500.com" onclick="window.open(this.href);return false;.
The engine is not finished yet, Karl said the cylinders are still at the machine shop. Did get the re-cut and finished heads back.
Getting the R6 forks fitted with softer fork springs from Progressive.
Having the billet clutch cover refinished by Diamond Back Designs, the machine patterns on the cover looked have half assed finished.
I want the cover to have the same look as the triple clamps.
Re:
Hi Keysdave , was wondering how the Cruzin Image RG 400 pistons , such as piston life & ring life , how many miles on pistons have you done . thank you in advance , Kind Regards AndrewKeysdave wrote:Hi Geakins, Nice project, I just finished my RG400 project some months ago. My bike is stock except for high flow air filter, jets, and float valves. Otherwise all stock, including bodywork. The 400 is seems faster than my 2X stock RG500's. I see your 500 pistons, are those from cruise-image on ebay, curious to see how they work for you. I dont think they have that machined flat for the wrist pin thrust washer, that good be added easy enough. I have a set of those in my RG400 and they have the machined flat and work great. Can not wait to see your finished product!
New tires and 90 degree valve stems from Kurveygirl.
A word of caution on the 90 degree valve stems,...... have seen these fly off at high speed.Not a good idea.
Seen the same thing with fitting bling "skull" valve caps..... will rip the valve right out of the rim.
350cc prod. SCTA Bonneville World Land Speed Record holder
350cc prod AMA Bonneville National Land Speed Record holder
500cc prod SCTA Bonneville World Land Speed Record holder
AMA no.1 Plate holder x 2
Pioneer of Motorsport Hall of fame
