Hi. A couple of my oil pipe unions that fit into the reed block rubbers are a bit loose and turn reasonably easily. I'm worried about a possible air leak path. What have people done to over come / seal these up. Just in case!
Thanks in advance
Pete
Possible leak path - Fix applied now
Re: Possible leak path
I have just re fitted by oil pump and new clear hoses. I also noted that the pipe fittings could be rotated.
Not sure if it has an effect. I am rejetting at the moment as I have gone a bit too rich in the mid range.
If you're worried about leaks you can test to give yourself some peace of mind. Start the bike and while it's running spray some carb cleaner around the oil inlet fittings. If your RPM increases you have a leak. If the RPM doesn't increase you have nothing to worry about.
Possible leak path - Now fixed
Problem solved
O ring around oil injector union shaft and a little bracket to compress and keep it in all in place
Now that is a nice job, Perfect fix
1985 RZv500
1984 RZ500 Hybrid
1986 RG500 Walter Wolf
1986 RG500 Skoal Bandit
1984 RZ350
1984 RZ350 Hybrid
1981 RD350LC
1981 RD350LC Hybrid
2009 CR500AF Supermoto 250X
2007 CR500AF 250X
1988 YSR50 (2)
1989 VFR750R RC30
1984 GPZ750 Turbo
1984 RZ500 Hybrid
1984 RZ350
1984 RZ350 Hybrid
1981 RD350LC
1981 RD350LC Hybrid
2007 CR500AF 250X
1988 YSR50 (2)
1989 VFR750R RC30
1984 GPZ750 Turbo
Re: Possible leak path - Fix applied now
Thanks, will fit to all 4 cylinders. 3 out of 4 fittings are loose
