It is currently Mon Jul 23, 2018 6:38 am
 Post subject: SRX250 Fuel petcock
PostPosted: Sat Aug 12, 2017 11:42 pm
It appears that the srx250 petcock (51Y-24500-01-00) is the same as the 500 petcock (47X-24500-01-00). Is this correct. Same number sequence except for the 47X vs the 51Y. It looks like it has the same/similar fittings...... Anyone else check this out?
 Post subject: Re: SRX250 Fuel petcock
PostPosted: Sun Aug 13, 2017 10:59 am
Petcock is the same but outlet is smaller. I swapped it out with the one from my old leaking one.
PostPosted: Sun Aug 13, 2017 11:45 am
Mike, so you are using the SRX petcock?? or did you pull the guts out of it to repair the 500 petcock. If you are using the SRX petcock, does it flow enough fuel?
Thanks.
PostPosted: Mon Aug 14, 2017 10:31 am
I removed the outflow pipe from the SRX and used the outflow from my old petcock. It's a press fit.
PostPosted: Mon Aug 14, 2017 1:59 pm
Thanks!!
