How Are These Pipes Made?
Re: How Are These Pipes Made?
Its the same technique but robot welded on the joints and the can is human welded on hence the different pattina.
Thanks, Kenny!
Good to hear from you.
I'm still dreaming about exotic pipes.
Also crazy about this photo from Unobtainium Welding.
To me, this looks like stainless. Not sure. I would love to have pipes with colored welds like this.
How is it done? Are those even welding beads I'm looking at?
Is that "Unobtainium Welding" script on the pipe? How is that done?
smoker
I had lunch with BT today. Have you asked him? What can he say?
1991 3MATZR250SP
!993 3XVTZR250SP
1996 RGV250(Lucky Strike)
1994 MC28SP
1995 MC28SP
1996 MC28SP
1985 RG500(Walter Wolfe)
1984 IT490
1985 RZV500R
1985 NS400R
1985 NS400R
1997 VFR750
1992 FZR1000
RGV400
TZR500
TZR350
1990 RZ350
1971 Porsche911S
!993 3XVTZR250SP
1994 MC28SP
1995 MC28SP
1996 MC28SP
1984 IT490
1985 RZV500R
1985 NS400R
1985 NS400R
1997 VFR750
1992 FZR1000
RGV400
TZR500
TZR350
1990 RZ350
1971 Porsche911S
My instincts tell me that BT doesn't fuck around.giron wrote:smoker
I need to know exactly what I want, have the bike ready, and be ready to transport - just in case he says "yes". I've also read that BT is a very desirable fabricator for race bikes, and I'm guessing there's no shortage of work for him. So, I think he would need to have some interest in my project.
Basically, I need custom titanium pipes. Should be no problem for BT. Then, I can get the pipes polished and color annealed/anodized from someone that does that kind of stuff.
I'm actually close to being ready for 3 sets of custom pipes.
Maybe this would be color "anodizing" as opposed to color "annealing".
I translated from Japanese, so not sure:
"Coloring processing is not painting but plating.
I can make such a gradation with the thickness of the oxide film."
I think the color anodizing is done with different voltages of electricity, similar to using different temperatures of heat.
Not sure if one technique is better than the other for pipes. Would definitely like to find a company that is experienced with coloring pipes.
Started to realize that making pipes with more curves, helps to keep the length shorter.
Exactly Pete, but technically the length is similar but it ends up protruding less. The RZ in particular needs the serpentine style to keep the fat part of the chamber under the bike for the best functioning pipe design. Much more difficult on the Rz compared to the RG with the RZ's lay down lower cylinders. Same issue with the V Twin 250's. I have a pair of Nikons for my MC28 that are just wild with curves in the extreme! The lower pipe goes forward to get a large centre section under the belly of the bike as the lower cylinder is even below horizontal. The 250's breathe a lot more than the 500's so they need a fat belly in comparison to the RZ and RG unless they are ported significantly. The production Jolly's and JL's seem narrow and seem compromised by the stock swingarm particularly the GP design without a banana swingarm. I'm not a pipe designer for sure but I think the RZ lower pipes need to crossover to be optimum design. Definate eye candy in my opinion!
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1985 NS500 Spencer p
1989 TZR500 Biaggi p
1984 RZV500 Rainey p
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
And especially on the upper RD500 cylinders they prevent the cans sticking out like they're about to poke out the eyeballs of anyone following you ....Smoker wrote:Started to realize that making pipes with more curves, helps to keep the length shorter.
Smoker said
Ideally the RZ uppers should cross over as well like my old Nikons do. Also, any backpressure issues having different length silencers top and bottom? I have some real short JL ones that would make a long set of straight uppers protrude at least 4-5" lessStarted to realize that making pipes with more curves, helps to keep the length shorter.
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
I see lots of pipes with this finish.
Is it mild steel welded with oxy-acetylene?
Maybe this Pete https://www.youtube.com/watch?v=BGEkBf87vU4" onclick="window.open(this.href);return false;
Thanks, but doesn't answer my question because they don't show the pipes until they're polished, and the welds are blue colored with a torch.silverstrom wrote:Maybe this Pete https://www.youtube.com/watch?v=BGEkBf87vU4" onclick="window.open(this.href);return false;
Pretty sure their "coned" pipes are fake. Stamped pieces welded together, and welds added to give the "appearance" of real hand coned.
Yes.Smoker wrote: Is it mild steel welded with oxy-acetylene?
[/img]
The main visible difference to TIG is the much wider heat influence zone with acetylene.
I posted these RZV500 pipes in my build thread, but they should be here, too.
The main frame appears to be unmodified. Would love to have pipes shaped like these. Note the lower cross-over pipes.
