Yamaha RZV500R <PULSAR> engine project
Pasha
Re: Yamaha RZV500R <PULSAR> engine project
#31 Post by Pasha » Thu Jun 02, 2016 3:34 pm
O-rings came at last. Now I can finish heads drawings.
Pasha
#32 Post by Pasha » Thu Jun 02, 2016 3:57 pm
Stock 100mm and beautiful Hot Rods 115mm.
Beautiful bottom honed surface ))))
Center webs from Yambits. Someone here asked if quality is good enough for such a low price?! No. While grinding and polishing pin got -0.01 (21.99) and because of not good enough balancing on the equipment while manufacturing pin had oval shape. You could see on pics. Else more 0.02 and pins are round shape )))))
The only way to get a gap 0.02 is to make new needles. Didn't find 11.8mm (length) needles, so regrind from 13.85mm. Needle cage should be reassembled and milled to fit new needles.
Pasha
#33 Post by Pasha » Thu Jun 02, 2016 4:06 pm
New long studs to centered both interface plates and cylinders.
Modified PW rack.
SS exhaust springs.
Pasha
#34 Post by Pasha » Thu Feb 11, 2021 3:44 am
Hi fellows. Need your advice to clarify correct dimensions. My crank collars are 35.4mm despite oil seal is 35.00, and thickness 14.6mm. Does anyone have an opportunity to measure yours?
Darrell
#35 Post by Darrell » Thu Feb 11, 2021 9:42 am
How impressive! Thank you for the details and great photos, and good luck as you continue with this fascinating project.
Pasha
#36 Post by Pasha » Sat Feb 13, 2021 3:52 am
From my point of view fastest and easiest way to set 180 deg for my cranks.
Side bottom conrod clearance was changed to 0.75mm for better lubrication with the cost of dimension between central webs. Labyrinth seal is less in width for 1 mm as well.
Cranks are ready for installation, but can't be installed at a moment. Need your help with dimensions from previous post. :smt010
steveho
#37 Post by steveho » Sat Feb 13, 2021 10:50 am
Pasha wrote: Thu Feb 11, 2021 3:44 am Hi fellows. Need your advice to clarify correct dimensions. My crank collars are 35.4mm despite oil seal is 35.00, and thickness 14.6mm. Does anyone have an opportunity to measure yours?
Right, i finally found my spare ones, and measured a couple, and they have identical dimensions (digital vernier)
OD, 35.00mm
Thickness, 14.57mm
Hope this helps! :cool:
tacky1
#38 Post by tacky1 » Sat Feb 13, 2021 12:37 pm
Very nice work. Looking forward to hearing her run.
lost1750GTV
#39 Post by lost1750GTV » Sat Feb 13, 2021 1:43 pm
!!! Serious stuff !!!
Pasha
#40 Post by Pasha » Sat Feb 13, 2021 7:19 pm
steveho wrote: Sat Feb 13, 2021 10:50 am
OD, 35.00mm
Thickness, 14.57mm
Thank you so much!!!! Finally I can go further :smt003
Pasha
#41 Post by Pasha » Sun Feb 14, 2021 4:25 am
Pasha
#42 Post by Pasha » Sun Feb 14, 2021 4:31 am
Pasha
#43 Post by Pasha » Sun Feb 14, 2021 4:40 am
Crankcase now is ready to receive cranks.
Pasha
#44 Post by Pasha » Tue Apr 06, 2021 2:34 am
New crankshaft bushings transmission side let me assemble the bottom end finally.
Luther
#45 Post by Luther » Thu Apr 08, 2021 3:10 pm
Good work, can't wait to see more.
I think .75mm side clearance on rods is good. In mini mx at .5mm they overheat. I'm guessing yours will get run on track.
What did you decide on the exhaust boost to piston pin hole? I don't think 1.5mm will be a problem
