The manual states that the side clearance limit (max) for the crank should be 0.1mm/.04" - since these are two very different dimensions, one of these two dimensions listed in the service manual must be a typo.
The "0.1mm" measurement is approximately .004", which seems awfully tight for the side clearance maximum measurement - I am guessing the correct spec limit for this dimension should be 1.0mm (or .040")
Can anyone give me the proper range for the connecting rod side clearance? I would expect it to be between .015"-.020" with .040" limit being worn out... Rick, Bill, anyone?
Thanks!
What is the correct connecting rod side clearance spec?
Re: What is the correct connecting rod side clearance spec?
The correct limit for measurement "D", big end side clearance, is 0.25 -0.75 mm or 0.0098 - 0.0295 inches, or more simply, 0.01 - 0.03 inches.
For reference, that is the same value used for the RZ350 and TZR250.
Thanks Silverstrom... That makes a whole lot more sense than the service manual spec of 0.1mm. I appreciate the info and confirmation.
Happy to help
John
John
