RZ500 Performance pipes
maser01
#1 Post by maser01 » Tue Jul 26, 2016 8:30 am
Hey guys,
looking at a good aftermarket exhaust system for my RZ. :mrgreen:
Can anyone recommend a tried and tested brand and what tuning mods are required to get them working.
Also looking at replacing front fork springs to help with the new Wilbers shock just fitted, anyone help with brand of good springs that :cool: will do the job please?
Many thanks,
T
Love classic 2 Strokes
Regards,
T Newts
1984 Yamaha RZ500 L
1981 Husky WR430
1974 Yamaha DT175 B
1995 Suzuki RGV250 T
1979 Suzuki GS850 GN
2000 Husaberg FE600E
2004 Aprilia RSV1000r
1981 Yamaha IT250H
Re: RZ500 Performance pipes
#2 Post by Smoker » Tue Jul 26, 2016 1:50 pm
Kenny at http://www.twostrokeaddicts.co.uk" onclick="window.open(this.href);return false; is a great person to talk to about dyno proven pipes.
Questo vecchio rz
#3 Post by Questo vecchio rz » Wed Jul 27, 2016 12:06 am
This topic can be easy as chocolote milk or frustratingly convoluted, This is my opinion.
From what is available, "All " of them are going to increase the performance on a RZ not only from power, but additionally a massive weight loss.
If your bike is basiclly stock, in some cases rejetting might not be necessary nor recommended, but small changes would likley help optimize the bike.
Some consideration should be given to your riding "style" & what you want out of it, virtually all pipes commercially available that you can ( simply bolt up under to the stock bodywork) deliver very similar peak power numbers, but there are some that deliver fatter low & midrange power at lower peak rpm, Example: said pipes in above post, I'm not sure if they fit under stock bodywork with unmodified subframes. Your choice depends upon how you choose to ride and the feel you are after. I've ridden RZs with Toomey, Lomas and Jolly Motos they all work quite good and most who have them are perfectly happy with them. You also have a choice of material and cosmetics, from mild steel w aluminum silencers to stainless steel w carbon fiber or any combination of the two you desire. For most RZs, brands or materials dont matter one bit they all work just fine, especially on a stock or near stock RZ.
IMO ultimate performance will likley be similar with "all" avail pipes which( fit under the stock bodywork), but you may prefer a fatter midrange as like those listed in above post, it really does depend on your personal desired riding style. If you looking for maximum performance then the topic changes to modified subframes to allow optimum "custom" pipe diameters and carb jetting w better breathing filters, reeds etc..
I dont put alot if stock in dyno numbers, really not much at all as often road results tell a diffrent story. Please be aware thats my opinion, if you do there are plenty of examples out here & on the internet. I think youll be happy no matter what you choose. As far a current "new" commercially available pipes I think there is only Jim Lomas and Jolly Moto. JL, Lomas craftsmanship is far superior and easilly equalls or surpasses most custom pipes available. There are smaller custom pipe builders as well one being Kenny in the U.K.(mentioned in above post) Swarbrick & Brian Turfrey in the U.S., also Gary @ Spec 2. which you can find all about in this forum. As far as well known pipes that are used and not in production any longer are Arrow, Toomey, & some other U.K. builders as well. Again all are good choices each has its drawbacks & advantages as well.
As far as springs go, www. RaceTech and gold valve emulators w progressive springs are pretty nice.
Im sure many here can also recommend more choices and thoughts.
Last edited by Questo vecchio rz on Wed Jul 27, 2016 8:06 pm, edited 5 times in total.
Royal Enfield 500
RZ421/YZR track bike(project)
maser01
#4 Post by maser01 » Wed Jul 27, 2016 7:26 am
Yes............no doubt a very interesting topic with many varying opinions :-?
I'll start doing some research on what pipes will suit my riding style :twisted:
Thanks for the responses much appreciated :smile:
Regards,
T Newts
1984 Yamaha RZ500 L
1981 Husky WR430
1974 Yamaha DT175 B
1981 Yamaha IT250H
giron
#5 Post by giron » Wed Jul 27, 2016 1:54 pm
you should not only focus on your riding style, but also where you will be riding. When I lived in southern California. It was mostly a congested parking lot. The weekends either the Angeles crest highway or early Sunday morning Griffith park. The pipes for southern California where all the congestion were at. The mass produced pipes without mentioning names were fine. Now I live in northern California where I'm five minutes from roads like Angeles crest highway. I can appreciate Brian Turfrey pipes.
1991 3MATZR250SP
!993 3XVTZR250SP
1996 RGV250(Lucky Strike)
1994 MC28SP
1995 MC28SP
1996 MC28SP
1985 RG500(Walter Wolfe)
1984 IT490
1985 RZV500R
1985 NS400R
1985 NS400R
1997 VFR750
1992 FZR1000
RGV400
TZR500
TZR350
1990 RZ350
1971 Porsche911S
David de Botton
#6 Post by David de Botton » Sun Nov 06, 2016 3:15 am
As an apprentice bike mechanic, it was common just to burn out the muffler & scrape out the ehader as best you can.
Years later I owned my own workshop
An aircraft mechanic came in an saw all the RZ 500 pipes hanging up.
He walked over and picked one up & commented on how heavy the pipe was. I said it was full of carbon & un burnt oil
He took the set of 4 pipes to work and put them all in an acid bath. He returned the pipes a week later and all 4 were as clean as the day they were made.
To cut short
By cleaning the pipes it brought back the original pipe volume. In doing so the bike carbureted much better & the bike pulled well from low down to top end.
From that day on I never did an engine rebuild without acid bathing the pipes :-)
The factory go to a lot of trouble to design.
It was common to just change the main jet from the stock #195 down to #165.
This worked very well.
As for the YPVS....its total crap
Try locking the power valve full open.
Then go for a ride and enjoy hitting 6,000 RPM and doing wheelings a lot easier than ever before :-)
Last edited by David de Botton on Wed Nov 09, 2016 4:45 am, edited 1 time in total.
David de Botton
#7 Post by David de Botton » Sun Nov 06, 2016 3:18 am
Has anyone tried the Original Yamaha TSI Spec exhaust pipes??
( specs sheet posted here on the forum )
With the other modifications included...a 30% increase on power through the range is AWESOME.
I am seriously considering getting a set made....Just wondering who has thgese pipes on their bike NOW ??
begbie
#8 Post by begbie » Sun Nov 06, 2016 9:42 am
David de Botton wrote: As for the YPVS....its total crap
Now try locking it fully down and tell us it it's still total crap. Sheesh some people.
#9 Post by MK » Sun Nov 06, 2016 11:41 am
Sorry, this statement is pure BS. That had to be said.
Everyone who has a Yamaha with a PV (be it the 350, a TZR or the RD500) immediately reckons when its not functioning.
Questo vecchio rz
#10 Post by Questo vecchio rz » Sun Nov 06, 2016 11:58 am
David de Botton wrote:As for the YPVS....its total crap
Yes that comment should be striken from the record, it has no validity and is simply a completley uneducated statement. :smt009
The YPVS allows the exact same topend performance fully open or locked open. A functioning YPVS system greatly improves low & midrange. & transition performance while allowing all the benefits of topend.
No debate will even be considered, Please, do some research & you will then understand :smt018
Royal Enfield 500
phildu31
#11 Post by phildu31 » Sun Nov 06, 2016 12:29 pm
Wheeling ability of a bike is a result of the variation of torque delivery among RPMs of its motor.
But not a sign of efficiency.
After all, it's a matter of taste.
#12 Post by MK » Sun Nov 06, 2016 2:58 pm
Questo vecchio rz wrote: The YPVS allows the exact same topend performance fully open or locked open.
Worse than that.
Measure with locked open valves and then with the controller active. The latter one will have a slightly higher max. performance, though you'd expect exactly the same peak.
It's just in the 1-2 HP region and I have no theory why, but belive me, it's a true fact.
You can even see this effect in the EngMod simulation.
David de Botton
#13 Post by David de Botton » Wed Nov 09, 2016 4:48 am
ok guys....I hear it load and clear :-)
