Hello.
I had just mounted new Yamaha original clutch plate, but it still slippering.
Does any one know if there is any stronger spring that will fit? And is there some kind of oil who is recomended to get rid of the problem?
/ Johan from Sweden
Clutch problem-slippering
Re: Clutch problem-slippering
What oil are you using. Did you replace the fibers and the metals. Are the metals dished
Now problem solved have mounted recomended TSI springs and adjusted clutch arm. Working perfect.
// Johan
// Johan
