Plugs
Plugs
#1 Post by silverstrom » Wed Jan 11, 2017 2:30 am
I've just ordered 2 sets of crank seals from my local shop. The plugs for the balancer and rear crank are NLA. Does anyone know a source for new plugs?
I have some used plugs here in my spares and will reuse if required. When reusing them, do you apply a bit of crankcase sealant to the perimeter of the plugs, just to ensure they never leak?
I ask because I have 2 engines to build from empty cases.
tacky1
Re: Plugs
#2 Post by tacky1 » Wed Jan 11, 2017 2:40 am
I reused the plugs on 5 different 500 engines John and never had a problem. I would check and make sure there was no damage to the lips on the side. I did seal mine with the same sealant I used to seal the crank cases. I use 3 bond 1211
Re: Plugs
#3 Post by silverstrom » Wed Jan 11, 2017 2:45 am
Thanks Paul.
WVWRZ500N
Re: Plugs
#4 Post by WVWRZ500N » Thu Jan 12, 2017 12:54 pm
John,
Put a bit of sealer on the oil seal surface as well as the flats when you're resealing the case halves.
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
