Clutch Spring Bolts
rd84
Clutch Spring Bolts
#1 Post by rd84 » Sat Sep 09, 2017 7:44 pm
Hi,
Since the clutch spring bolts are NLA I wondered what else could be used instead ?
Kalim
Re: Clutch Spring Bolts
#2 Post by Kalim » Sun Sep 10, 2017 3:26 am
I'll have to figure this out soon too, when I assemble the clutch back.
The cross print of my bolts are in a terrible state.
I'm pretty sure any standard screw, countersunk head, with the right length will fit.
There are normally prisonner shims, but any shim with similar size will do the job too.
I'll retrieve the original ones and drill them slightly bigger to fit the new screws.
This is all assumptions, I'm looking for advices too :smile: .
rd84
#3 Post by rd84 » Sun Sep 10, 2017 5:30 am
Thanks Kalim - I'll try a few bolts and see if I can find a solution - I'll post here if I do.
tacky1
#4 Post by tacky1 » Mon Sep 11, 2017 1:10 pm
I used R6 bolts on mine and they work fine
rd84
#5 Post by rd84 » Mon Sep 11, 2017 1:46 pm
tacky1 wrote:I used R6 bolts on mine and they work fine
Thanks for that- can you confirm which model R6 please - just in case they're different
tacky1
#6 Post by tacky1 » Mon Sep 11, 2017 6:32 pm
Yep, They are different, I had to look for the part number, the first set I bought didn't work.
These definitely work, I have them in 2 engines and no probs http://www.partzilla.com/parts/detail/y ... 02-00.html" onclick="window.open(this.href);return false;
Kalim
#7 Post by Kalim » Tue Sep 12, 2017 3:03 am
Thanks !
rd84
#8 Post by rd84 » Tue Sep 12, 2017 7:44 am
Yamaha part number :- 90159-06002
Many thanks.
