Individual / single heads from another Yamaha
Vinpg
Re: Individual / single heads from another Yamaha
#16 Post by Vinpg » Thu Dec 21, 2017 9:43 pm
I'm looking for some pics I had but no luck, the pic posted with the oring installed is mine, the heads will have 4 removable domes all the orings needed two heads all new copper washers and new stainless taller acorn nuts, price will be $595.00 for everything
RC45
#17 Post by RC45 » Thu Dec 21, 2017 10:13 pm
Any mods to the cooling lines needed?
CBR1000RR SP2 HRC WSBK
TZ500V/OW53 Track bike
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
TZR250 3MA Track Bike
427ci C5 Z07
Vinpg
#18 Post by Vinpg » Thu Dec 21, 2017 10:22 pm
No absolutely none, and if you cut a stock rear head in half (yes I have) you'll see that water when it enters has a path that allows the water to go straight to the outlet, I'm sure a lot makes it into the barrel, but it can go in and out easily, mine have a wall that forces the water into the cylinder and then exits the head above the exhaust, I believe they will run cooler than stock, but all water hoses are in the same location as stock, also has the tapped holes in the lower head for fairing brackets like the OEM heads do.
ns86
#19 Post by ns86 » Thu Dec 21, 2017 10:42 pm
So this photo I posted is what you are selling Gus?
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1985 NS500 Spencer p
1989 TZR500 Biaggi p
1984 RZV500 Rainey p
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
Vinpg
#20 Post by Vinpg » Fri Dec 22, 2017 1:40 am
Yes that is 1
RC45
#21 Post by RC45 » Fri Dec 22, 2017 2:14 am
How do they go together? Does it use o-rings and gaskets?
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
tacky1
#22 Post by tacky1 » Fri Dec 22, 2017 2:34 am
Do you have a pic of one installed
Vinpg
#23 Post by Vinpg » Fri Dec 22, 2017 10:50 am
No they only use o-rings, that pic is the bottom, the dome snaps in then that other piece which is also upside down has an o-ring holds the domes in, I'm still searching for pics.
Stinke
#24 Post by Stinke » Sat Dec 23, 2017 9:57 am
Hi, I installed Gus´s heads, they work great done 400km´s on them. The temperature is always around 70 Celcius. But I have done the "cooling mod" to the rear cylinders as well. I have a few pics on the assembly of the heads but I don't want to open Photbucket. Where do I load up pics easy for publication?
Gus can I buy a set of O-rings for the future?
2 x rd 500 -84
Rd 350 ypvs -84
Rd 250 -74
Kh400, t20
The best of swedish metal: https://youtu.be/gkBt7yLXyDk" onclick="window.open(this.href);return false;
Vinpg
#25 Post by Vinpg » Sat Dec 23, 2017 5:41 pm
Yes I have to buy quantities like crankshafts even o-rings, I'll have a site once the cranks arrive and the heads will be there along with pistons and other stuff, I'll keep you posted. Not sure on the pics I always have a rough time.
tacky1
#26 Post by tacky1 » Sat Dec 23, 2017 6:53 pm
Stinke wrote:Hi, I installed Gus´s heads, they work great done 400km´s on them. The temperature is always around 70 Celcius. But I have done the "cooling mod" to the rear cylinders as well. I have a few pics on the assembly of the heads but I don't want to open Photbucket. Where do I load up pics easy for publication?
Do you have any pics of the cooling mod, All the old pics are deleted, It would be nice to get an idea on how it looks, Thanks
ns86
#27 Post by ns86 » Sat Dec 23, 2017 9:36 pm
Try postimages.org it works great. Works better than Photobucket ever did for me, https://postimages.org" onclick="window.open(this.href);return false;
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
RC45
#28 Post by RC45 » Sun Dec 24, 2017 5:15 am
Or Imageshack.com - hell, a manila folder of xerox's tied to a can and a string would be better than photobucket these days :)
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
jeff10
#29 Post by jeff10 » Mon Dec 25, 2017 9:18 am
How are these one - piece billet heads aligned over the piston /squish-band accurately without access to the individual engine /piston manufacture let alone any obvious method of dowling or pinning these into place ?
Vinpg
#30 Post by Vinpg » Mon Dec 25, 2017 2:41 pm
It aligns exactly like a stock head, the squish band is 13.5 degree's a 8mm wide band and has I believe a clearance of .032 I'll post all dimensions when I get done with Xmas and head to Michigan
