Can someone please verify for me the proper orientation of the power valve seal when installing it in the Holder? I have heard of the seal being installed backwards and was not able to see the orientation on the parts fiche or the service manual and was unable to find any references/pictures searching the web site.
Install with lettering on seal lip facing outward and the 6 symmetrical projections facing inward toward the cylinder
OR
Install with the 6 symmetrical projections facing outward and the lettering on the seal lip facing toward the cylinder
Thanks!
Power valve seal orientation
Re: Power valve seal orientation
You need the open sealing end facing inboard and the 6 castellations facing outboard.
Perfect - thank you for the info and the pictures!!
