few static timing qeustions !
Posted: Tue Apr 03, 2018 3:08 am
hey guys
few questions on checking static timing for my zeel unit
current it set at 34
i have read some older posts and im still not understanding how to check it , one said degree wheel and dial indicator , just finding it a bit hard as only way to check with timing light is through the hole when running
i have taken the timing bung out , and with a basic timing light at 1200 rpm static 34 . 2000rpm on zeel set to 19
the mark on the case lines up with the bottom mark on flywheel , but if i change the static in zeel to 37 i can get the mark on the case to fall between the 2 marks on the flywheel as per the manuals test
is this a correct test ?
if not layman's terms for a correct explanation , whole timing thing is over the top of my head at the moment
thanks
thanks
