500 Two-Stroke Tech
500cc GP-Replica Tech Forums
Search  FAQ  Register Login
It is currently Fri Sep 21, 2018 7:07 am
Post new topic Reply to topic  [ 7 posts ]
 Post subject: Fuel Filters: Anyone running them down stream from tank?
PostPosted: Sat Apr 28, 2018 8:02 am
I'd like to put a set on from the tank to the petcock. There's not much room anywhere before or after the petcock. What is the ID of the stock fuel line from the tank?
Looking for ideas.
RZ is still running strong!
 Post subject: Re: Fuel Filters: Anyone running them down stream from tank?
PostPosted: Sat Apr 28, 2018 8:15 am
Looking for ideas.
Hi Loaded, I've put 2 genuine Honda filters on. I'm pretty sure the ID is 9mm might be 10. I'll did out the part number this afternoon.
Sent from my HTC Desire 530 using Tapatalk
Current Bikes
1984 47X RD500LC, 2007 GSXR750, 1987 VF500F2F
Past Bikes Include
PostPosted: Sat Apr 28, 2018 7:08 pm
The Honda part number I used is 16900-MG8-003. The spigots are 11mm OD. I put one on each fuel line in a stagged position.
Current Bikes
Past Bikes Include
PostPosted: Sat Apr 28, 2018 8:23 pm
Thanks for the info !
PostPosted: Sun May 27, 2018 1:47 pm
These filter are big! How do you have yours routed ?
PostPosted: Sun May 27, 2018 1:50 pm
I can't send you a picture at the moment but I staggered them near the tank outlets.
Current Bikes
Past Bikes Include
PostPosted: Mon May 28, 2018 7:24 am
I did the same , just use the T- piece behind the opener, and use the outlet for the left side towards the right carbs, an the right side outlet for the left carbs. Then you can use longer hoses in a bow. They will be goin around the radiator hose. The filters are place near the carb inlet
Users browsing this forum: No registered users and 4 guests
