500 Two-Stroke Tech
500cc GP-Replica Tech Forums
Search  FAQ  Register Login
It is currently Thu Nov 15, 2018 10:31 pm
Post new topic Reply to topic  [ 4 posts ]
 Post subject: Cool Runnings
PostPosted: Sat Apr 28, 2018 8:34 am
I fired up the RD for the first time in 6 months and refurb last weekend. Started 3rd kick and idles sweetly but the bottom right exhaust is much cooler than the other 3. I've cleaned and checked the carb OK. Spark is good too. Is there any common fault you can think of to cause this?
Regards
Linx
Sent from my HTC Desire 530 using Tapatalk
Current Bikes
1984 47X RD500LC, 2007 GSXR750, 1987 VF500F2F
Past Bikes Include
 Post subject: Re: Cool Runnings
PostPosted: Sat Apr 28, 2018 9:46 am
Is your injection oil level the same as it was when you parked it? When a bike sits the oil can leak through the injection pump, into the motor, and collect in the pipe. Most commonly affects the lower left pipe. If that's the case take the pipe off and dump out the oil.
Regardless, I'd change the spark plug.
PostPosted: Sat Apr 28, 2018 10:18 am
How do I dump out the oil?
Current Bikes
Past Bikes Include
PostPosted: Sat Apr 28, 2018 2:17 pm
I found the pilot jet was partially blocked. Wouldn't blow out with carb cleaner but cleared with a little brass wire .
Current Bikes
Past Bikes Include
Users browsing this forum: No registered users and 8 guests
cron
