500 Two-Stroke Tech
500cc GP-Replica Tech Forums
Search  FAQ  Register Login
It is currently Fri Sep 21, 2018 1:30 am
Post new topic Reply to topic  [ 6 posts ]
 Post subject: Carbs wont stop pi$$ing out fuel..........
PostPosted: Thu Jun 14, 2018 3:28 pm
Just trying to finish off the 500, but the carbs wont stop pi$$ing out fuel, despite them being fully rebuilt with new shut off valves, and the float height set to 24mm, as per the revision..............
PLEASE HELP!
 Post subject: Re: Carbs wont stop pi$$ing out fuel..........
PostPosted: Thu Jun 14, 2018 4:48 pm
The only way a carb can piss fuel is if the float valve isn't working properly or the float height is too high. Time to open one up and see what's going on.
I suppose there is one other way and that is if the drain valve is left open, but there is an obvious difference in where the fuel is pissing out.
1985 RZ500 1GE Spec
1986 RG500 ATR
1986 NS400R
1987 TZR250
1988 Honda RC31
2007 DL650 VStrom
PostPosted: Fri Jun 15, 2018 8:34 am
Did you use OEM or Mikuni float valves and seats ?
Did you check the fuel level in each carb as per the service manual ?
PostPosted: Mon Jun 18, 2018 7:22 am
New shuts used altho kit original Mikuni ones.
Float heights set to 24mm.....just checked float height using the pipe up the side method and it is showing flat heights are too high...
So 24mm is not high enough then....
PostPosted: Mon Jun 18, 2018 8:25 am
24mm is roughly correct - can you confirm that you have measured the float height as described in the manual ? The adjustment tang must only just touch the valve - the weight of the float must not bear on it - so you angle the carbs to achieve this.
Good - luck - it’s a miserable process !!
PostPosted: Fri Jun 22, 2018 6:50 pm
Right..............
Brand new Mikuni shut off valves, and float heights set with the pipe up the side method...................................
And success!!!!!!
There is a difference between the Tourmax shut offs and the Mikuni ones.................
Moral.......buy genuine!
