Exhausts De-restrict.RZV500R
PJ
#1 Post by PJ » Mon Dec 14, 2009 8:47 pm
Sorry if this has been asked before,
My RZV500 that I intend to de-restrict, I believe needs collars which are in the exhausts to be removed. Two questions
Where are these collars are located in the exhaust pipes.
Can they be removed with out damage to the exhaust as I do not want to have to cut pipes to remove.
Pat
hybrid
Site Admin
#2 Post by hybrid » Mon Dec 14, 2009 10:45 pm
Plenty of info on this if you do a search.
..... or I could do it for you
http://www.rzrd500.com/500phpBB3/viewto ... =rzv#29363
It does not look like you can remove them without cutting the collars off the pipes.
You might be able to grind the welds off from the end of the pipe, but the pipe insert looks like it needs to come out towards the rear of the pipe.
I robbed these pics from jackson.40
Ronnie
#3 Post by Ronnie » Tue Dec 15, 2009 7:38 am
unless you can get your hands on a second hand set of pipes of an RD/RZ. you have to do the jetting on the carbs aswell. again, plenty info on here about that.
rdryder
#4 Post by rdryder » Tue Dec 15, 2009 2:15 pm
Hey Pat, I am looking to get a set of Jolly Moto pipes in the new year so I could do you a deal for mine if interested?
There are no marks/dents on them , and I have Swarbrick alloy end cans fitted to them.
If interested give me a call, think you have my number.
Have a good x-mas. Paul
ride it like you stole it!
PJ
#5 Post by PJ » Wed Dec 16, 2009 1:22 pm
Hi Guys,
Thanks for the feedback, I intend to remove the ehxausts during the Xmas holidays and I will let you know the update.
Paul thanks for the offer and I would be interested, I,ll give you a call to discuss as I also had intended to buy after market pipes rather than tamper with the originals.
Regards
Pat.
PJ
#6 Post by PJ » Sat Jan 02, 2010 6:03 pm
Hi All,
Happy new to everybody.....I worked on the removal of the collars over Xmas hoildays, They are held in by 3 spot welds which I had to grind off, a nasty job but the collars do come out and there is no need to cut the exhausts....Next job is jetting.
Regards
PJ
garfield
#7 Post by garfield » Wed Jan 06, 2010 6:07 pm
well done PJ...Keep good notes....i will be needing them :grin:
mwatkins
#8 Post by mwatkins » Fri Jul 13, 2012 8:24 pm
PJ wrote:Hi All,
Regards
PJ
hi pj, i am new to the site and new to the rz, i plan on doing the same as you with the pipes, how did you get on with the jetting.
buy the way are there many 500 in ireland
mark
V4 Heaven
Re: Exhausts De-restrict.RZV500R
#9 Post by V4 Heaven » Wed Oct 17, 2018 5:01 pm
Hi all,
Got a debate going on another forum.
I’m aware that the 51X top pipes are restricted as the photos on this thread show.
Can anyone please confirm whether the 51X lower pipes were also restricted? Whereabouts and how were they restricted?
Cheers.
Gettin' kinda squirrely!
jackson.40
#10 Post by jackson.40 » Wed Oct 17, 2018 5:22 pm
Yes the lower pipes are restricted the same way as the top pipes.
If you look at the last photo you will see the four restrictors which have been removed from the top and bottom pipes.
V4 Heaven
#11 Post by V4 Heaven » Wed Oct 17, 2018 5:52 pm
Thanks for clearing that up.
I saw the 4 restrictors but weren’t sure if that was two lots of upper pipe restrictors or not.
phildu31
#12 Post by phildu31 » Thu Oct 18, 2018 10:03 am
V4 Heaven wrote:Hi all,
Cheers.
Forget Facebook forums : You'll find more stupidity than awareness there...
jackson.40
#13 Post by jackson.40 » Thu Oct 18, 2018 12:16 pm
Agreed but there are some gems on there sometimes.
Someone on the site has found that a Ski-Doo coil HT plastic wire clip is the same as the rd/rz/rzv500 coil.
The only problem is they don't know the part number :grin:
I have it if anyone needs one.
Jeff B
#14 Post by Jeff B » Thu Oct 18, 2018 2:30 pm
Cheers.
and don't forget repetition!
podman
#15 Post by podman » Fri Oct 19, 2018 3:12 pm
jackson.40 wrote:Agreed but there are some gems on there sometimes.
You have the part number or the clip?
