Front Fork bushes success!!
hector1000s
#1 Post by hector1000s » Tue May 13, 2014 3:35 pm
Well as some of you may know the front fork bushes on the rd500 are not a seperate item from the stanchion additionally they are no longer available aswell!!
I posted on here months ago and was advised to try Wemoto.com as they stock quite a few bushes, after searching their website it appears that they do not stock the sizes needed for the rd500, so did a lot of searching on web and eventually found a company here in the UK called K-tech and ordered some bushes. Fitted them today and they are perfect fitment, so am a very happy bunny now!
Heres the part numbers for ya all
Top guide bushes are listed as Part no GBS-003 Showa 37mm guide bushes 37x12x2.00
Bottom sliders bushes are listed as Part No SBS-003 Showa 37mm guide bushes 37x 20
AND they only cost £26 odd inc delivery and took 2 days to arrive, excellent service!!
cheers Colin
Marsupilami
Re: Front Fork bushes success!!
#2 Post by Marsupilami » Tue May 13, 2014 4:47 pm
Not that I'm currently in need of them, but thank you very much for the info!
rd84
#3 Post by rd84 » Tue May 20, 2014 5:47 pm
Excellent detective work !
Many thanks.
V4 Heaven
#4 Post by V4 Heaven » Wed Feb 01, 2017 6:39 pm
Very good news. I'm going to get some!
Gettin' kinda squirrely!
#5 Post by silverstrom » Wed Feb 01, 2017 7:06 pm
I bought mine here http://www.ridejbi.com/fork-inner-bushing/" onclick="window.open(this.href);return false;
V4 Heaven
#6 Post by V4 Heaven » Wed Feb 01, 2017 7:13 pm
Did it feel any different or any smoother?
#7 Post by silverstrom » Wed Feb 01, 2017 7:15 pm
The slides are identical to stock.
tacky1
#8 Post by tacky1 » Wed Feb 01, 2017 10:01 pm
Great job, Thanks for sharing the info...
V4 Heaven
#9 Post by V4 Heaven » Sat Feb 04, 2017 1:46 pm
Ordered mine directly from K Tech in the U.K. They arrived next day!
jackson.40
#10 Post by jackson.40 » Sat Feb 04, 2017 4:03 pm
You can get them from Ebay UK as well.....................
http://www.ebay.co.uk/itm/Set-of-4-inne ... Swd0BV1zXy" onclick="window.open(this.href);return false;
Speed Freak
#11 Post by Speed Freak » Mon Mar 13, 2017 5:05 am
Measured the K-Tech bushes yesterday.
Height: 19,7-19,75mm (K-Tech), 19,8-19,85mm (Yamaha) - the width of the pocket in the fork leg is 20mm.
Diameter with closed gap: difference smaller than diameter deviation around the part (+-0,1mm)
Thickness: 1mm (K-Tech), 0,9-0,95mm (Yamaha, old worn bushes)
Haven`t checked the diameter in mounted conditin at the moment, but from the measurements above there will not be much difference, only a slightly bigger diameter because of wear.
Result:
They are 99,9% the same but I think not from the original supplier (for Kayaba) because they are golden on the inner side and the Yamaha parts are black.
Maybe I can get some original Kayaba parts...
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
V4 Heaven
#12 Post by V4 Heaven » Mon Mar 13, 2017 8:08 am
Sometimes I think life is too short to worry about 0.1mm!
Speed Freak
#13 Post by Speed Freak » Mon Mar 13, 2017 9:37 am
I don`t worry about it, the message should be that they will work.
This difference is maybe smaller than the production tolerance of such parts.
But if I get the parts from the original supplier... why not? :mrgreen:
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
V4 Heaven
#14 Post by V4 Heaven » Mon Mar 13, 2017 9:39 am
Good man. Could you let us know part numbers if you do?
rubberfingers
#15 Post by rubberfingers » Mon May 15, 2017 6:38 pm
I fitted these when I rebuilt my forks - all good so far
cheers Andy
RD500
TZR250 2MA
TZR250 3MA
TDR250
YZF600R
DT125RE
XS750E
DTR125
FZ1
