Exhausts
BigGuy
Re: Exhausts
#16 Post by BigGuy » Sun Jan 29, 2017 12:50 pm
Jarrettvp wrote:I had the frame painted and the foot rest hangers were powder coated. They did a fantastic job for me. They also tapped out all the threaded holes afterwards to make sure I have clean threads. I had a big smile on my face when assembling it today. Have a look under engines. The same company did my engine.
That powder coating on the foot rest hangers looks great! What did you do with the rubber damper things that the lower pipes hang from? From what I understand the coating process requires the parts to be totally stripped? Did you manage to get tthem out without wrecking them? Did you replace them? I ask because I just bead blasted mine and was wondering if there was a better option than the paint?
Shake "N" Bake!
Speed Freak
Re: Exhausts
#17 Post by Speed Freak » Sun Jan 29, 2017 4:36 pm
I would replace them anyway, they are still available (~20€/pc) and the rubber isn`t getting better after 30 years.
If you don`t want to destroy the old parts simply use a pipe which fits to the outer diameter of the part to get the force into the steel ring and not into the rubber.
As far as I remember I found a hexagon socket with correct diameter - today I would use my small lathe.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
jackson.40
Re: Exhausts
#18 Post by jackson.40 » Sun Jan 29, 2017 5:05 pm
If you do fit new dampers make sure you fit them in the correct position.(see link)
http://www.rzrd500.com/500phpBB3/viewto ... per#p49323" onclick="window.open(this.href);return false;
BigGuy
Re: Exhausts
#19 Post by BigGuy » Sun Jan 29, 2017 5:58 pm
Sweet! I never would have guessed they were still available, funny the things you can and cannot get? Thanks for the tip on the orientation also, makes sense.
Shake "N" Bake!
kpke
Re: Exhausts
#20 Post by kpke » Mon Jan 30, 2017 11:58 am
I have successfully pressed those dampers out and then back in (in the correct orientation no less :smt002 ) after powder coat.
Good luck. :smt023
Jarrettvp
Re: Exhausts
#21 Post by Jarrettvp » Tue Jan 31, 2017 7:33 pm
Anyone suggest a finish on the swinging arm? Powder coat as well, so it matches the foot rest hangers and frame?
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
Re: Exhausts
#22 Post by silverstrom » Tue Jan 31, 2017 7:44 pm
20 minutes ago I had a swingarm in my hands and asked myself that same question. Power coat is certainly more durable, but I'm wondering if it will cover the indexing marks for the chain adjusters (even though they are mostly useless).
Aren't the swingarms anodised from Yamaha and not painted?
rd84
Re: Exhausts
#23 Post by rd84 » Tue Jan 31, 2017 11:05 pm
The swingarms are anodised silver - powdercoat just doesn't look right - I think vapour blasted, satin polished, brushed finished then two pack matt clear coat might be the best finish available - however I'm about to try and get my swingarm vapour blasted - satin polished, brush finished then anodised to see how it comes out.
I'll record the results to show how it goes.
Re: Exhausts
#24 Post by silverstrom » Tue Jan 31, 2017 11:42 pm
Looking forward to seeing that Paul. It has been a concern here since I decide to do the project.
I've heard that no one has had any success yet at matching the original anodizing.
rd84
Re: Exhausts
#25 Post by rd84 » Wed Feb 01, 2017 11:43 am
silverstrom wrote:Looking forward to seeing that Paul. It has been a concern here since I decide to do the project.
I've decided to take the risk and find out what is possible - might take quite a few weeks to sort out though.
podman
Re: Exhausts
#26 Post by podman » Wed Feb 01, 2017 3:50 pm
rd84 wrote:The swingarms are anodised silver - powdercoat just doesn't look right - I think vapour blasted, satin polished, brushed finished then two pack matt clear coat might be the best finish available - however I'm about to try and get my swingarm vapour blasted - satin polished, brush finished then anodised to see how it comes out.
I believe the restorer of the bike in this issue of PS magazine vapour blasted the swingarm to get back that original finish.
[url]Image
Jarrettvp
Re: Exhausts
#27 Post by Jarrettvp » Wed Feb 01, 2017 5:56 pm
I am very interested to see what the results are like with your swinging arm. I have been pondering for some time on what to do for the best. I have removed mine, used a de-greaser solution and rubbed it down with fine wire wool. See pictures attached. Anyone know where I can get a new rubber chain guard for the swinging arm?
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
Re: Exhausts
#28 Post by silverstrom » Sat Feb 04, 2017 3:42 am
Jarrettvp wrote: Anyone know where I can get a new rubber chain guard for the swinging arm?
Talk to Hans here http://www.rzrd500.com/500phpBB3/viewto ... 11&t=13258" onclick="window.open(this.href);return false;
Jarrettvp
Re: Exhausts
#29 Post by Jarrettvp » Sun Feb 12, 2017 4:46 pm
So I've cleaned up my swinging arm now and it looks pretty good. I am going to get it vapour blasted first and then make a decision on whether to anodise it or brush it and clear coat it. Any comments or suggestions would be appreciated. I'm looking to try to keep it looking original as much as possible
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
rd84
Re: Exhausts
#30 Post by rd84 » Mon Feb 13, 2017 9:36 am
That's looking really nice
