Looking for a couple of these in M8
https://www.ebay.co.uk/itm/Yamaha-Suzuk ... 1438.l2649" onclick="window.open(this.href);return false;
Any ideas what they are called as searching for them has been a nightmare!
Any help with sourcing M8 versions would be much appreciated.
Ade
Does anybody know what these are called??
Re: Does anybody know what these are called??
You want a rubber grommet with an M8 insert/spacer? Exactly like that, or perhaps like this https://www.ebay.co.uk/itm/x5-rubber-gr ... SwhQhY1rXj" onclick="window.open(this.href);return false;
Check out the seller's other items. He has grommets in different shapes and sizes.
Hisilverstrom wrote:You want a rubber grommet with an M8 insert/spacer? Exactly like that, or perhaps like this https://www.ebay.co.uk/itm/x5-rubber-gr ... SwhQhY1rXj" onclick="window.open(this.href);return false;
The seller appears to have several sizes available.
Thanks for this.
My preference would be to have the ones like i posted but the ones you advised could work.
Thanks Ade
I have loads of grommets here in various sizes. If you get stuck and do need something specific let me know and I'll see what I have.
