Kickstand Spring
Kickstand Spring
#1 Post by Smoker » Thu Mar 08, 2018 8:07 am
Is Yamaha part #90507-29009-00 the correct kickstand spring for the RZV500?
Does anyone know where to get a proper fitting stainless steel spring?
Thanks!
tacky1
Re: Kickstand Spring
#2 Post by tacky1 » Thu Mar 08, 2018 11:39 am
Partzilla have it in stock. https://www.partzilla.com/product/yamaha/90507-29009-00" onclick="window.open(this.href);return false;
#3 Post by Smoker » Thu Mar 08, 2018 1:07 pm
tacky1 wrote:Partzilla have it in stock. https://www.partzilla.com/product/yamaha/90507-29009-00" onclick="window.open(this.href);return false;
Part number 90507-29009-00 supersedes the original spring part number 90507-29033. Available from Yamaha.
-Is part number 90507-29033 the correct kickstand spring for the RZV500?
-Does replacement part number 90507-29009-00 fit the same as original part number 90507-29033?
-Does anyone know of a stainless replacement kickstand spring that will fit the RZ500?
I've been searching, but can't find an active parts microfiche for the RZV500.
#4 Post by silverstrom » Thu Mar 08, 2018 3:45 pm
http://www.rzv500r.net/Tech_docs/1GG-PL ... age_57.jpg" onclick="window.open(this.href);return false;
http://www.rzv500r.net/content.html" onclick="window.open(this.href);return false;
jackson.40
#5 Post by jackson.40 » Thu Mar 08, 2018 4:22 pm
Yes 90507-29033 is the correct spring for the RZV500
90507-29009 fits the same but is bright zinc plated and the original was olive plated.
Speed Freak
#6 Post by Speed Freak » Thu Mar 08, 2018 5:13 pm
https://www.federnshop.com/en/products/ ... rings.html" onclick="window.open(this.href);return false;
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
#7 Post by Smoker » Thu Mar 08, 2018 8:17 pm
Thanks for the good info and the microfiche links!
I'll use the 29009 spring, until I find a stainless spring.
I checked out that spring supplier, too. It'll take some time to figure out if they have it. :mrgreen:
#8 Post by silverstrom » Fri Mar 09, 2018 12:01 am
Would this do if the length is correct? https://www.ebay.com/itm/Yamaha-Stainle ... kW&vxp=mtr" onclick="window.open(this.href);return false;
#9 Post by Smoker » Fri Mar 09, 2018 2:12 am
silverstrom wrote:Would this do if the length is correct? https://www.ebay.com/itm/Yamaha-Stainle ... kW&vxp=mtr" onclick="window.open(this.href);return false;
Would definitely do, but looks too short.
Listed as 125mm eye to eye.
Total length on the spring I have is about 138mm.
I sent a message to the seller asking for the total length.
#10 Post by silverstrom » Fri Mar 09, 2018 5:52 pm
If you are using the stock RZ side stand you do have the option of repositioning the spring tab. It's an easy cut and weld. I've had tabs moved. It's unnoticeable afterwards.
#11 Post by Smoker » Fri Mar 09, 2018 7:16 pm
silverstrom wrote:If you are using the stock RZ side stand you do have the option of repositioning the spring tab. It's an easy cut and weld. I've had tabs moved. It's unnoticeable afterwards.
Not using the OEM stand.
Hopefully making a custom kickstand, so you're right about the spring pin placement. But, I don't want the spring coils to move up towards the upper spring pin. Need clearance to pass in front of the kickstand mounting bolt head.
Still trying to find a stainless spring that matches the OEM spring. It's a nice upgrade for any RZ500 that doesn't have to be all original.
