Page 1 of 2
bellypan stone bracket
Posted: Thu May 10, 2018 6:41 pm
by shergar
is there anywhere i can buy these now ? https://www.cmsnl.com/products/mole-1_4 ... vS70YYh3q0" onclick="window.open(this.href);return false;
Re: bellypan stone bracket
Posted: Thu May 10, 2018 6:46 pm
by rd84
Posted: Thu May 10, 2018 6:50 pm
by shergar
these are the parts that hold on the bellypan mesh yes ?? ta
Posted: Thu May 10, 2018 6:56 pm
by shergar
these are the parts that hold on the bellypan mesh is this correct mate ?? ta
Posted: Fri May 11, 2018 2:11 am
by rd84
You also need the top bracket - the dampers above just protect the bodywork and allow the top bracket to grip the bodywork - if you don't have one they are available from one of our forum members.
Ps the rubber dampers can be replaced by a short strip of u section rubber like you get on the screen edge trim for example - this is not 100% accurate but is cheaper and works ok.
Also lockwire the mesh section to something nearby so it isn’t lost if it comes loose.
Posted: Fri May 11, 2018 2:47 am
by rd84
Posted: Fri May 11, 2018 5:21 am
by shergar
rd84 wrote:Hi,
Thanks for advice and help mate , p
Posted: Fri May 11, 2018 10:03 am
by shergar
rd84 wrote:Hi,
would you have a picture of how its fitted to the fairing and bracket please , yes i bought a top bracket from one of the forum lads , cheers
Posted: Sun May 13, 2018 3:23 pm
by rd84
Does this help ? .....
The bottom mesh is slid down into the bottom of the fairing aperture - the top bracket is slid down until it grounds onto the top of the mesh - the moles are positioned on the fairing edge so they lie under the side protrusions of the top bracket - the top bracket screws are tightened to clamp the top bracket onto to the moles and fairing - the top bracket can't move in theory and in turn this stops the mesh from moving up and falling out - in practice it can so wire the mesh to the YPVS debris shield so if the assembly comes loose you don't lose it since they are a little bit expensive to replace nowadays.
Posted: Sun May 13, 2018 4:16 pm
by silverstrom
It's nice to have the stone guard, but not essential to install it. Unless you are riding in gravel it's a mostly useless item. I have mine in storage (so the bike is complete) but I won't install it. If you do decide to actually install it on your bike use a tether as in the photo above or risk losing it. Many have fallen off.
Posted: Mon May 14, 2018 4:12 pm
by podman
rd84 wrote:Does this help ? .....
Nice one Paul, the tip about wiring it to the YPVS shield is a great idea.
Posted: Tue May 15, 2018 2:07 pm
by shergar
Great info and pics lads ta , just one more question on the two stroke oil bracket I seen on a video somewhere that the bracket swivels round to allow filling is this the way it should be as mine is just bolted down ? Ta
Posted: Tue May 15, 2018 5:34 pm
by tacky1
It swivels P, The bracket has a bolt that allows it to swivel
Posted: Tue May 15, 2018 6:57 pm
by shergar
tacky1 wrote:It swivels P, The bracket has a bolt that allows it to swivel
any pics of the correct type paul as im lost on this one ? ta
Posted: Tue May 15, 2018 7:30 pm
by silverstrom
