bellypan stone bracket
Re: bellypan stone bracket
Would you have a picture of the correct bolt John just hard to make out how it looks and works mate , ta
my bikes.
YL1 , AS3 (2) , YAS1 (2) , LC 350 ,
RD 400 , 400 DAYTONA , KH 250 s1 ,
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
You'll find 2 good views here https://www.cmsnl.com/yamaha-rd500lc-19 ... vxF9OSG-Uk" onclick="window.open(this.href);return false;shergar wrote:Would you have a picture of the correct bolt John just hard to make out how it looks and works mate , ta
if you screw the correct bolt down tight how dose it swivel ? ta
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
the bolt to buy is 1euro and 19.50euro to post total 25.22 inc vat what a joke , there robbers that crowd , psilverstrom wrote:You'll find 2 good views here https://www.cmsnl.com/yamaha-rd500lc-19 ... vxF9OSG-Uk" onclick="window.open(this.href);return false;shergar wrote:Would you have a picture of the correct bolt John just hard to make out how it looks and works mate , ta
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
Loosen the screw, swivel the bracket. Swivel the bracket, tighten the screw.
If Yamaha doesn't have the screw available do what everyone else does: go through your hardware box and find any Yamaha screw that is the correct colour and size and then use it. No one will know and no one will care. It's a screw
no its just that when i seen the part on youtube i was on the understanding that it was spring loaded somehow at the screw which ment you didnt have to loosen each fill , p
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
Its 66 pence from Fowlers...post will sting you a bit more so see what else you may need , there's always something!
https://www.fowlersparts.co.uk/parts/40 ... 9/oil-tank" onclick="window.open(this.href);return false;
Which typically means Yamaha has it available.podman wrote:Its 66 pence from Fowlers...
The screw has a special slot machined into it so you can loosen or tighten it with either a screwdriver or a coin.shergar wrote:no its just that when i seen the part on youtube i was on the understanding that it was spring loaded somehow at the screw which ment you didnt have to loosen each fill , p
