84 yamaha rd 500 no spark .
Re: 84 yamaha rd 500 no spark .
Yeah, you mentioned that all single components work, so there is only the pickup mount position and the wiring harness (incl. ignition switch).
In the latter one the kill switch grounds the red cable from the source coils.
If you physically disconnect the kill switch and the ignition switch, it cannot be goundeed anywhere. Try if it starts then.
As a counterprobe you can measure resistance against ground on the red/white cable on either the CDI or stator connector (both work).
If the kill switch is set to off, it should go to around zero (before it should be at a high value in the megaohm range) . Same for turning the key to off position.
Just an update guys
after admitting defeat the bike was sent to an auto electrician this week early reports back are the generator is not producing enough power for the spark. I cannot understand this as the generator and flywheel work on another bike.
I will keep you posted
thanks
thanks
They work or they don't. They test serviceable or they don't. If they worked on one bike they should work on another. If they don't work on your bike now you have a wiring problem. Just my 2 cents worth.stevig2003 wrote:I cannot understand this as the generator and flywheel work on another bike.
As you asked about signal forms and amplitudes:
I had these on my HDD (both from RD350YPVS).
The tach signal is equal to the RD500 and I strongly assume the PickUp should be, too.
Oszilloscope signals of running engine: Pick-Up has some 7 V Amplitude, Tach 150-170 V
Pickup Signal; Engine spun by hand: Pick-Up has some 1.2 V Amplitude
Hi guys ive got exactly the same problem with my 500 been trying to get a spark for months. Only thing i havent changed is the pickup Ive moved it closer to flywheel to no avail. Has anyone bought one from a aftermarket outlet and adapted it to fit. ?
AT LAST A SPARK..
Well guys after a few weeks of scratching my head I have finally got a spark.
I still have not managed to get an Oscilloscope but I managed to get a better multi meter.
I have gone through all the harness again after the generator was sent away for repair on the advice of a local bike shop. When we got the exchanged generator back all of the resistance readings were the same as the old one. A note in the package saying ours was ok please try this one !
put it on the bike and once again no spark ...
I measured the voltage out of the cdi on the orange wires to frame earth and was getting 3.2 volts ( not enough to spark) I then cut the cdi earth (black wire) which was measuring 0.01 ohms to frame earth) and measured direct between orange and black out of the cdi 18.5 volts. it looks like I had a fault on the cdi earth circuit under load.
When I connected the black wire out of the cdi onto the coil I now have a spark. I think one of the first posts on this thread mentioned the clump of black wires I did check this first and all earth point were reading under 1 ohm of resistance.
One quick tip for any basic electrical guys needing to fault find a simple LED connected across the pulse wires from the generator ( white/green and white/red ) will give you some indication if you are actually getting a pulse.
if it does not work try changing the wires around because the LED only works one way.
you can also check the orange and black wire with this method out of the cdi it wont tell you if the voltage is correct but will flash to tell you the circuit is working.
thanks again guys for all the help
Webs wrote:Hi guys ive got exactly the same problem with my 500 been trying to get a spark for months. Only thing i havent changed is the pickup Ive moved it closer to flywheel to no avail. Has anyone bought one from a aftermarket outlet and adapted it to fit. ?
We bought a second hand standard one from Germany in our fault finding it might be going spare
I will ask the owner if he would like to sell it.
You can test with a simple LED if you suspect its not working
stevig2003 wrote:Webs wrote:Hi guys ive got exactly the same problem with my 500 been trying to get a spark for months. Only thing i havent changed is the pickup Ive moved it closer to flywheel to no avail. Has anyone bought one from a aftermarket outlet and adapted it to fit. ?
For completeness sake here's my EFI RZ 350 pick up signal.
In idle it's short under 10V.
I'm using an aftermarket pickup from Ignitech.
- Attachments
- IMG_20180324_122709.jpg (201.91 KiB) Viewed 2689 times
Sorted
Sorry I have not posted the fix and I thank everyone on the forum for their help
So the top and bottom of this problem was actually the tachometer.
When the mechanic had rebuilt this bike after stripping and restore he connected the tachometer up incorrectly.
The pulse wire from the cdi was actually connected to the wrong pin on the tachometer. I could not pick up the fault as I guess it was electrically isolated through the cdi.
The issue was not actually there until you tried to start the bike.
I managed to get a spark as I started disconnecting earth wires from the bike and noticed as the bike ran for around 20 seconds the tachometer was not working . The tachometer on this bike didn’t have any markings for wires so I guess it’s an easy mistake. Lucky the guy restoring it took pictures so after trawling through them I found the correct wire up.
Started first kick after that and has been on the road since.
Thanks guys
I hope this helps someone out in the future
Thanks guys
Wow, now that would have been a tough one to solve, Who woulda thought the bloody Tacho would cause a spark problem.
Thanks for posting back, Good to know!!!
Well it's kind of typical for RZ350 and 500 tachs.
The black/yellow cable that is the input for PV controller and tach holds the voltage at the capacitor that is switched via the thyristor.
If it's grounded, there's no spark.
That's why a professional debug starts with disconnecting everything that does not create a spark. I'd have rated a professional electrician could have spotted that on the wiring diagram...
Fantastic news, and unexpected. Great you have it sorted.
www.2smoked.com
82 RD250LC '251LC' YPVS
