Shielding HT leads?
wolfgangh
Shielding HT leads?
#1 Post by wolfgangh » Sun Mar 11, 2012 5:09 pm
A friend and ex-world championship racer (in the 70´s and 80´s) is telling me that some factory bikes had shielded HT wires (from the coils to the caps) because of negative influence of coolant tubes close to the wires. I cannot imagine that.
Can someone confirm that water / coolant close to the HT wire or plug is reducing spark energy at high RPM?
beek
#2 Post by beek » Sun Mar 11, 2012 7:33 pm
No never heard of that.
a lot of the older race bike had all the electrics away from the coils as that did effect things like wild tachos ect
we often see all the cdi box ect at the rear of the bike i guess for this reason.
A ht lead is pretty well shielded anyway i cant believe that and the coolant tubes are rubber as well. ok some modern bike use a combination of alloy tubes and hose but i just cant see the problem
Andrew
#3 Post by Andrew » Mon Mar 12, 2012 11:48 am
Were the coolant 'tubes' made of a type of metal???
Andy (UK)
RZV500R
FRC
Faster Faster !!!
RC45
#4 Post by RC45 » Mon Mar 12, 2012 12:54 pm
I can tell you the current coil/lead cap setup send out a signal strong enough to disable the accelerometers and sensors in a data logger.
Somehow I am thinking the leads/coils are big an mean enough o look after themselves, it is the other gizmo's in the the vicinity you need to shield.
CBR1000RR SP2 HRC WSBK
TZ500V/OW53 Track bike
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
TZR250 3MA Track Bike
427ci C5 Z07
