rev counter
rev counter
rev counter stays @ zero at tickover only moves when revved ??
- aaronmvrider
when bike is revving does it read correct...
my bike had a similar issue with instruments... and rev counter would die when i hit brakes or turned on lights
i replaced the main fuse on the battery positive lead... 12v / 20 w
my issue is fixed.... hope that helps
my rides
rz 500 1984
2 x rz 350 1984
mv agusta f4 1000 2004
rz 500 1984
2 x rz 350 1984
rev counter
spot on dodgy conn on main feed from batt to ign.ta
- aaronmvrider
that has made my day.... it solved your issue...
i chased this issue for quite a while and even parked the bike contemplating sending it to a mechanic to diagnose....
i ordered a new battery and the mobile battery company showed up with the wrong battery... so i looked further....
glad i have been some help.... i have been helped many times and its good to offer the same back... passing it on...
Aaron
Aaron
my rides
rz 500 1984
2 x rz 350 1984
rz 500 1984
2 x rz 350 1984
