Evenin all can anyone tell me if there is a supplier for zeels in the uk?, I currently have a 350 ypvs one fitted, and need to get the valves opening correctly @ the correct revs!!
cheers colin
UK Zeeltronic supplier
- aaronmvrider
Gibsons will make you a set
Mick abbey will make you a set
Mark dent will make you a set
Gibsons will be similar price to JL (inc cans)
Micks will be significantly cheaper but your cans
Mark Dent will be the most expensive
Unless you can find some s/h ones,
but give mick a bell you will be shocked that his price is similar to s/h pipes
Or you can get a swarbrick kit !
Mediocrity is a sin !
