500 Two-Stroke Tech
500cc GP-Replica Tech Forums
Search  FAQ  Register Login
It is currently Wed Nov 14, 2018 11:21 pm
Post new topic Reply to topic  [ 9 posts ]
 Post subject: Zeeltronic wiring query?
PostPosted: Sun Oct 14, 2012 6:42 am
Hi
I have now fitted the zeel cdi/pv controller, i have one query with the Gray wire, should i connect it to the Orange/Black wire?
my bike is standard rd500 UK spec does not have a TPS!
The wiring diagram says "if TPS not used then connectO/B andGr. Program only 100% ignition curve" Can anyone explain this to me please??
cheers colin
 Post subject:
PostPosted: Mon Oct 15, 2012 12:47 am
Site Admin
Basically when you don't have a TPS, you join those wires together. It tells the zeeltronic that you have 100% throttle all the time.
So when you join the wires, you only configure the 100% curve values in the zeeltronic, because the other values are not used.
From memory, when you use a TPS with Zeeltronic there are 3 curves that you can configure for different throttle openings.
http://www.2strokesdownunder.com
http://www.winsto.net/piggie/
http://www.winsto.net/projects/
 Post subject:
PostPosted: Mon Oct 15, 2012 1:44 pm
Hybrid, thanks for that that explains it! I just didnt want to connect them up without checking and f**k it up!
cheers colin
 Post subject:
PostPosted: Mon Oct 15, 2012 6:14 pm
Site Admin
No problem.
There should be a TPS value displayed on the programmer when the bike is turned on I think.
So if you see 100% there all the time, you've done it right.
I've done the same thing with mine now because I don't have TPS any more since I dumped the injection.
 Post subject: Re: Zeeltronic wiring query?
PostPosted: Wed Feb 19, 2014 6:08 am
What is TPS?
PostPosted: Wed Feb 19, 2014 10:14 am
Throttle Positioning Sensor................. I think?
www.vinsbuilds.proboards.com
PostPosted: Sat Aug 26, 2017 9:18 am
Hi.
I'm pretty much doing the same at the mo.
As I'm thick.....and also "Dont" have a TPS.....can anyone just confirm......
"The Orange/Black from the Zeeltronic CONNECTS directly to the Grey"......and does not connect to the servo at all?
It "DOESN'T" connect to the "Yellow/Blue" at the servo and then run a feed to the grey??.
Correct??
I'd rather be scared to death than bored to death!
PostPosted: Sat Aug 26, 2017 12:52 pm
If no TPS, then O/B gets connected to Gr & Y/Bl on servo.
I.e. The Y/Bl on servo always gets connected to the O/B on the Zeel, but if no TPS, then just connect the Gr to those colours as well.
Remember to program 100% in the set-up.
Rgds.
RD400F, with Dave Freist (RIP) carb mods
TDR250 special, carbon, lighter, faster!
Harley Wide Glide, 103 cubes of torque
YZR500 Replica, Latest passion. A money pit!!! A keeper!
Latest purchase, RD500 in Marlboro colours! A project....
PostPosted: Sun Aug 27, 2017 6:35 pm
Cheers Steveho.👍🏼
Users browsing this forum: No registered users and 4 guests
