Black tape for harness
kpke
#1 Post by kpke » Fri Oct 19, 2012 10:57 am
Some of you have done harness modifications and/or restorations.
I think there is a special tape for this application.
What tape did you use to wrap the harness with?
Where did you purchase it from?
Thank you!
PaulGreen
#2 Post by PaulGreen » Fri Oct 19, 2012 11:54 am
Hi,
I've cleaned up my wiring harness. The tape's nothing special, just like self-amalgamating tape but without the sticky. As you stretch the tape around the harness it only sticks to itself rather than the wires.
Makes the harness look much cleaner. I got mine here in the UK but a quick google/ebay search for 'harness tape' will surely bring something closer to home.
I found that i needed to put a turn of electrical tape at the end of each run to help stop the tail coming loose.
Cheers,
Paul.
hybrid
Site Admin
#3 Post by hybrid » Fri Oct 19, 2012 7:19 pm
Beek put me onto some stuff called COROPLAST.
It's a cloth type harness tape. Works very well. If you're not looking to keep the bike completely stock, I would use this stuff for sure.
kpke
#4 Post by kpke » Sat Oct 20, 2012 9:21 am
Thanks guys.
Not stock for sure so I will research as suggested.
I was mostly curious about the "stickiness" of the adhesive.
I know that regular electrical tape will separate or "move" and leave sticky goo all over.
Don't want that.
Murphy.NZ
#5 Post by Murphy.NZ » Sat Oct 20, 2012 4:31 pm
Hybrid, is Coroplast kinda a mesh tube that expands as push it to allow poking your plugs etc through?
