Bike has spark but none of the electrical work?
perryml
#1 Post by perryml » Mon Mar 11, 2013 9:49 pm
I cannot figure this out so I’m hoping someone else out there might be able to help. Here’s the situation:
- When I turn the ignition key nothing happens, however I took the plugs out and kicked the bike over and I have spark
- I mounted an external fan switch with a separate fuse and the fan works fine
- All fuses are good
- No lights, no power valve cycling, no horn, no turn signals, no brake lights
Someone mentioned it might be the rectifier…but the battery has full charge
Thanks, Mike
