remove or install battery no disassembly req'd????
bolly
#1 Post by bolly » Wed Jun 19, 2013 6:32 pm
lotsa good info about smaller sized batterys on the forum but I can't find what maximum size the battery can be to be able to remove it from the bike without removing the tailpiece and loosening the pipe.... anybody know the size of a battery that will work?
Mike Cichetti
Re: remove or install battery no disassembly req'd????
#2 Post by Mike Cichetti » Mon Jun 24, 2013 9:35 am
I always use RG500 batteries, just enough smaller to slip in and out. I'll give you the number when I get home.
Mike Cichetti
#3 Post by Mike Cichetti » Wed Jun 26, 2013 7:13 pm
The battery number is BTL5X-BS. Just enough smaller to clear the pipe.
bolly
#4 Post by bolly » Wed Jun 26, 2013 7:21 pm
excellent news Mike Cichetti!! I went with a stock battery for now as I was in a rush but I'll definately research that one you suggested, thanks!!!!
V4 Heaven
#5 Post by V4 Heaven » Thu Aug 01, 2013 5:00 pm
There is a knack to it but I can just get mine out with a bit of wiggling!
Gettin' kinda squirrely!
#6 Post by silverstrom » Thu Aug 01, 2013 8:22 pm
V4 Heaven wrote:There is a knack to it but I can just get mine out with a bit of wiggling!
Me too. Just take the side panel off and wiggle the battery out. It takes a few times to get it just right, but it is possible to remove and install it.
