power valve unit
dingle
power valve unit
#1 Post by dingle » Sat Oct 26, 2013 2:53 pm
i am newby to this website. im looking for some help, my electrical powervalve unit on my rd 500 47x model has been damaged by water and is no longer working. im looking for a replacement power valve unit or can someone recommend me to someone who may be able to help.
john dingle
bungerlowbill
Re: power valve unit
#2 Post by bungerlowbill » Sat Oct 26, 2013 3:39 pm
Hi dingle you have a couple of options, nick at twostrokeracelab does a repair service with dip switches,but it depends on the damage or try zeeltronic they do a programmable unit , failing that puchase rd350ypvs pwr valve unit and send to twostokeracelab who will replace the ic chip with dip switches which can be set to the desired pv opening rpm ranges.
I had mine done by nick top bloke to deal with , then swap 350 connetor with your 500 one regards bill
rd84
#3 Post by rd84 » Fri Nov 01, 2013 9:27 am
Do you mean the PV controller or the PV actuator ?
